[Feature Request] The ability to select the audio output within PlexAmp
Hi
Would it be possible to have included in PlexAmp the option to define an audio output so that we can assign the channels that music will play over?
I use VoiceMeeter (+Virtual Cables) to manage all my audio and while I can select an output in Windows Settings (App Volume Device Preferences), the setting never sticks, so whenever I close and re-open PlexAmp I have to go back to the Windows Settings, change it to something else then back again for it to play over the desired output again.
While the above is a time consuming workaround for Windows, other devices may also benefit from the option to select a custom audio output other than default.
I’d be keen to see something like this too, for slightly different reasons. If I’m using PlexAmp to send something to an AirPlay 2 speaker, I have to redirect my entire Mac audio, including system sounds. It would be nice to be able to redirect only the PlexAmp audio to the AirPlay speaker, similar to how the iOS app works.
Defining audio output, definitely.
Per-app AirPlay is something different/harder, but the iOS app running on Apple Silicon can already do that.
