PlexAmp Player Mac Airplay
Server Version#: 1.42.2.10156 Checking for Updates
Player Version#: 4.12.4
Hi there friends. I hope everyone is well.
When using Plexamp on iOS (same version) with airplay it works like a champ and I can select a speaker from within the app. When on the Mac running the lates OS, the only way to listen through airplay speakers is to select airplay from the control panel essentially sending all sound (safari tabs, windows, YouTube, etc.) to airplay vs. just the desired Plexamp application. This has never worked as far as I can remember. Tidal, AppleMusic, Spotify, etc. all allow application specific, speaker specific selection, and it is an “option” for Plexamp, it just has never “taken”. It just endlessly spins. This functionality would make the application that much better. Hoping the developer see this and can offer an existing solution or work on enhancing the experience further than the great experience it already is. Thanks in advance for feedback.
Have a great weekend ahead.
Try this out: GitHub - ronitsingh10/FineTune: FineTune, a macOS menu bar app to control volume for each app independently, route apps to different output devices, and apply EQ
Thank you for recommending this! This solves ALL my problems with getting PlexAmp to cast to my HomePod instead of screwing around with the awful Sonos integration that I can’t ever get working.
