Hej Gutter
Jeg er lidt nye med PLex har brugt Iphone til at stream fra min pc til tv, men vil gerne køre fra pc til appletv uden telefon.
Jeg får heletiden fejl på min apple tv Trailer are unavailable,
Har denne log
21:39:38 PlexConnect: started: 21:39:38
21:39:38 PlexConnect: Version: 0.4-dev
21:39:38 PlexConnect: Python: 2.7.8 (default, Jun 30 2014, 16:03:49) [MSC v.1500 32 bit (Intel)]
21:39:38 PlexConnect: Host OS: win32
21:39:38 PlexConnect: PILBackgrounds: Is PIL installed? False
21:39:38 Settings: getsetting enable_plexconnect_autodetect=True
21:39:38 PlexConnect: IP_self: 192.168.1.6
21:39:38 Settings: getsetting hosttointercept=trailers.apple.com
21:39:38 Settings: getsetting enable_dnsserver=True
21:39:38 DNSServer: started: 21:39:38
21:39:38 Settings: getsetting port_dnsserver=53
21:39:38 Settings: getsetting ip_dnsmaster=8.8.8.8
21:39:38 Settings: getsetting prevent_atv_update=True
21:39:38 DNSServer: ***
21:39:38 DNSServer: DNSServer: Serving DNS on 192.168.1.6 port 53.
21:39:38 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.6
21:39:38 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
21:39:38 DNSServer: forward other to higher level DNS: 8.8.8.8
21:39:38 Settings: getsetting enable_webserver_ssl=True
21:39:38 WebServer: started: 21:39:38
21:39:38 Settings: getsetting port_webserver=80
21:39:38 WebServer: ***
21:39:38 WebServer: WebServer: Serving HTTP on 192.168.1.6 port 80.
21:39:38 Settings: getsetting port_ssl=443
21:39:38 Settings: getsetting certfile=./assets/certificates/trailers.pem
21:39:38 WebServer: WebServer: Serving HTTPS on 192.168.1.6 port 443.
21:40:45 DNSServer: DNS request received!
21:40:45 DNSServer: Source: ('192.168.1.5', 65277)
21:40:45 DNSServer: Domain: ax.init.itunes.apple.com
21:40:45 DNSServer: ***forward request
21:40:45 DNSServer: -> DNS response from higher level
21:40:46 DNSServer: DNS request received!
21:40:46 DNSServer: Source: ('192.168.1.5', 59445)
21:40:46 DNSServer: Domain: p44-buy.itunes.apple.com
21:40:46 DNSServer: ***forward request
21:40:46 DNSServer: -> DNS response from higher level
21:40:48 DNSServer: DNS request received!
21:40:48 DNSServer: Source: ('192.168.1.5', 54322)
21:40:48 DNSServer: Domain: itunes.apple.com
21:40:48 DNSServer: ***forward request
21:40:48 DNSServer: -> DNS response from higher level
21:40:49 DNSServer: DNS request received!
21:40:49 DNSServer: Source: ('192.168.1.5', 55668)
21:40:49 DNSServer: Domain: trailers.apple.com
21:40:49 DNSServer: ***intercept request
21:40:49 DNSServer: -> DNS response: 192.168.1.6
21:41:25 DNSServer: DNS request received!
21:41:25 DNSServer: Source: ('192.168.1.5', 55594)
21:41:25 DNSServer: Domain: a771.da1.akamai.net
21:41:25 DNSServer: ***forward request
21:41:25 DNSServer: -> DNS response from higher level
21:51:33 DNSServer: DNS request received!
21:51:33 DNSServer: Source: ('192.168.1.5', 60967)
21:51:33 DNSServer: Domain: upp.itunes.apple.com
21:51:33 DNSServer: ***forward request
21:51:33 DNSServer: -> DNS response from higher level
21:56:26 WebServer: http request header:
Connection: Keep-Alive
Host: 192.168.1.6
21:56:26 WebServer: http request path:
/currentsetting.htm
21:56:26 Localize: aTVLanguage: en
21:56:26 WebServer: pms address:
21:56:26 WebServer: cleaned path:
/currentsetting.htm
21:56:26 WebServer: PlexConnect options:
{'aTVScreenResolution': '720', 'aTVFirmwareVersion': '5.1', 'aTVLanguage': 'en', 'aTVAddress': '192.168.1.6'}
21:56:26 WebServer: additional arguments:
22:11:27 WebServer: http request header:
Host: 192.168.1.6
22:11:27 WebServer: http request path:
/currentsetting.htm
22:11:27 Localize: aTVLanguage: en
22:11:27 WebServer: pms address:
22:11:27 WebServer: cleaned path:
/currentsetting.htm
22:11:27 WebServer: PlexConnect options:
22:11:27 WebServer: additional arguments:
22:13:26 DNSServer: DNS request received!
22:13:26 DNSServer: Source: ('192.168.1.5', 63608)
22:13:26 DNSServer: Domain: ax.init-cdn.itunes.apple.com.akadns.net
22:13:26 DNSServer: ***forward request
22:13:26 DNSServer: -> DNS response from higher level
22:13:27 DNSServer: DNS request received!
22:13:27 DNSServer: Source: ('192.168.1.5', 50425)
22:13:27 DNSServer: Domain: p44-buy.itunes-apple.com.akadns.net
22:13:27 DNSServer: ***forward request
22:13:27 DNSServer: -> DNS response from higher level
22:13:29 DNSServer: DNS request received!
22:13:29 DNSServer: Source: ('192.168.1.5', 59349)
22:13:29 DNSServer: Domain: itunes.apple.com
22:13:29 DNSServer: ***forward request
22:13:29 DNSServer: -> DNS response from higher level
For mig at se er der forbindelse men det virker bare ikke, syntes jeg har forsøgt i diverse forum men desvære uden held..
Håber i kan hjælpe.
Har Python 2.7
Mvh
Jacob
