File converter
here is a little app i put together, point it at your plex directory and it will convert all files from one type (.avi etc) to another and then delete the original file (work through the entire folder tree).
I had to convert over 5000 files and all the free programs i found put the files in a single folder meaning i would have to place them in the correct folders then delete the original.
Plex converter I have added the project to the folder (visual studio solution c#)
One what, to another what?
Can I suggest, that you post the source code as well?
Having an unknown binary work on my file-system simply ain’t going to happen, since who knows what it’ll do
…especially when their username starts with Devil :innocent:
one file type to another i.e. i had a number of .avi files that where almost unplayable so converted them all to .mkv
it is a visual studio project (just a wrapped ffmpeg) with the file rename
but .avi and .mkv are only containers… What matters more is the codec… With a simple container incompatibility it should just de-multiplex and re-multiplex the file, which takes very little resources… But if all it’s doing is that process ahead of time, you should be very detailed, edit your original post with what exactly is does and why…
Still, unless people has a crystal ball, they have no way of knowing, so please post the source code, or path to like a github repo
And you did :heart_eyes:
