I have assigned some sharing labels to my movies. I would like to see all the movies that DON’T have my new tag/label. Is it is possibles to see all the movies without a label? TIA
Huh… I wonder if the silence is because this is obvious and I should know already, or if this isn’t easy and there isn’t a solution. Anyone? Again, thanks in advance.
Couple of thoughts about the silence, then on to your issue…
The silence is partly due to no easy way to do what you ask. And that the requests for the tools to do this type of task have been ignored by the Plex Team for a very long time. (Black list filtering with logical operators would be a great way to do this, but it’s not something the powers that be want us to have.)
So, how to do what you want? There is a tool created by one of the ninjas called Plex2CSV. This looks at the library and outputs the info to a comma separated spreadsheet. T hen you can filter the spreadsheet to show the different labels or the lack of them. Then you open your PMS Web App and apply filters as needed and run Plex2CSV again to get an updated spreadsheet. Rinse, repeat until everything is properly labeled as you want.
This is about the only way I know of to do what you want…
This is the subject of several feature requests. You can add your vote by clicking ‘Like’ on the first message in this thread.
I appreciate both of your thoughtful replies. Bummed no solution, but I’ll vote/like accordingly. Thanks again.
