Server Version#: 1.15.5.994
Player Version#: 3.99.2
Filter by rating - how does this work ? Does it filter by the rating given by the scraper IMDB for example - or is it user ratings ?
Is there a way to filter by the scraper ? I might want to watch a movie with a minimum IMDB rating of 7.0 for example.
You can only filter by user ratings, from none to 5 stars.
Where do the stars come from - users or some other 3rd party ?
You have to set them yourself.
Thanks…
Maybe a feature request is looming
There is a “critic rating” filter.
I see this only as a ‘sorting’ criterium, but not as a filter.
Doh. You are right. I was looking at sorting, not filter.
Can you tell me how to do this.
edit
found it
In case others are following.
yeah - I found it and you can apply that to a filter, so I can filter my sci-fi with an imdb rating - which was exactly what I was after.
system
Closed
12
