Filter by Record Label uses "contains" not "equals" leading to incorrect matches
Server Version#: 1.20.2.3370
Player Version#: 1.20.0.1406
As the subject describes, this is leading to incorrect matches, if you notice in the screenshot below you will see the Freddie Hubbard album on label “CTI” but additionally albums on the label “Chain Reaction”
I would assume the matching here should be using BEGINS WITH or EQUALS not CONTAINS which appears to be the case.
Screen Shot 2020-10-01 at 12.53.03 PM
Just a quick note, the Chain Reaction titles do appear properly in “Chain Reaction” so the feature is working for most labels as it should but, over-reporting incorrect matches in some instances as described here
Thanks, keen eye! Fixed in the next release of Plexamp.
Awesome, thank you! I assume this also will push to the regular/OSX player as well? :pray:
no, that unfortunately turns out to be more complicated, will likely require server work.
Noted, appreciate it again!
