I’m trying to filter based on artist and track title. All of the titles I expect to see are showing up, but then there’s some which are appearing for no apparent reason. Here is a partial screen grab showing what I’m seeing.
The filter is not only showing “absolute” matches but also “fuzzy” ones.
So minor differencs in e.g. spelling are ignored.
Since the only difference here is a single letter (D instead of F) the search logic considers it a minor difference.
Did you try the search word "in F "
(with an extra space after F)?
It misses the ones with F at the end, but otherwise, it should be okay…
You could expand with or “in F,” etc…
