How can i find duplicate tracks in my playlist? Thanks for help me.
You cannot. Plex doesn’t allow you to add the same file twice to a playlist.
If you hear the same song twice within the same playlist, it means that you have two copies of the song in your library.
@OttoKerner thanks for your reply. If i have 2 compilation with same track, i can’t do anything for haven’t this track 2 times in my playlist?
Unfortunately not, unless you find the track by accident and remove it manually.
Ok, could be use have a table view, like in album section.
