Is there an easy way to find episode duplicates? My primary way in the past was using the search page. Now that’s gone finding tv episodes duplicate is impossible for me.
Just found out plex combined hunter x hunter (1999) with the 2011 version. Very annoying.
filter episodes by duplicates.
In order for “Duplicates” to show up as an option in the first drop-down, you must change the second drop-down choice to “Episodes”. Then you can change the first drop-down to “Duplicates” to see.
Thanks.
Lol that is a weird way of doing it tho.
The first drop down is the filter you are most likely to change often, picking by genre or actor or what-not. The second drop down changes how your content is shown, by TV Show (one entry per show) by Season (one entry per season per show) or by Episode (one entry per episode of every season of every show). This is unlikely to ever be changed.
The “Duplicates” filter on the first does not quite… work when it comes to the TV Shows filter. It doesn’t seem to me that entire shows would be duplicates, only individual episodes. Since you are sorting via TV Shows and not per episode, there is no duplicate to show, so it is not an option unless you are on Episode mode.
It’d make more sense if these two drop downs were swapped, but I think the show/season/episode drop down is unlikely to be changed as often, so was not given the prime real estate of being the first drop down.
