Ekomax
August 4, 2020, 5:40am
1
@sixones
Server Version#: DS918+ latest beta
Player Version#: latest Client version from Amazon App Store
Turning on refresh rate switching in the Plex Client of the Fire Tv Stick 4K causes Transcoding.
Logs:
FireTVStick4K.webarchive.zip (203,4 KB)
Plex Media Server.log.zip (103,0 KB)
Plex Transcoder Statistics.log.zip (4,4 KB)
best regards
Ekomax
Ekomax
August 6, 2020, 5:50am
2
@jesusmc
Could you take a look.
Thx and best regards
Ekomax
Thanks for providing those logs. After a quick investigation, I think it might be related to some issues we’ve fixed in latest 8.5 beta that you can find Android (mobile) beta release notes Is there any chance you could give it a go and see if it fixes your issue?
Thanks in advance
Ekomax
August 6, 2020, 11:45am
4
@jesusmc
Will try when back from work and report you
best regards
Ekomax
Ekomax
August 6, 2020, 4:34pm
5
@jesusmc
just gave it a try with the new beta
had to deactivate Resolution and Framerate switching for having correct aspect ratio with
PAL playback.
Ac3 passthrough (Spdif) works.
best regards
Ekomax
system
Closed
November 4, 2020, 4:34pm
6
