Fire TV update
Fire TV showed to update the app in the app menu. Installed, still shows last update of October 15 after the install?
Doesn’t seem to have fixed anything with codec support or the top right clock corner glitch. Custom Pre-rolls are working though.
If you don’t have an update, you don’t have any fixes? Wait for 2026.22.0?
Mine shows the same, maybe an oversight in how the release was published?
Confirmed it’s 2026.22.0 in the Plex app about screen. Double check what version you have there.
