Fix for People running a DD-WRT router and latest Plex issues regarding local network server connectivity
Hi all, I wanted to respond to the existing thread(s) with this reply but they had closed due to inactivity.
I came across the issue this morning where the latest Plex app for Roku, would not connect to my Plex server. Setting the setting in the app settings to always allow insecure connections worked, as well as setting security to disabled in the network settings of Plex Server directly. However, I think the the solution I came up with this morning is better suited for security minded people.
DISCLAIMER!
This solution is ONLY tested on routers running DD-WRT, and may NOT apply to others, use at your own risk.
OK, with that said, connect to the router’s setup page, usually http://192.168.1.1
Select the Services tab
Scroll down to DNSMasq, if enabled, click disable for No DNS Rebind.
Click Save, Click Apply Settings, reboot is optional here.
Restart Plex App on Roku, your server ā€œshould be functionalā€. I have also gone as far as setting my Roku Plex App to require secure connections and the server has worked fine. Granted, this is limited testing, but I’m going to assume here, that people here are above average user experience so will have at least heard of DD-WRT, if not run it, or another open firmware.
Below, I included a screenshot of correct section:
If security minded please do not disable DNS Rebind protection. Enter the following in the Additional Dnsmasq Options field box:
rebind-domain-ok=/plex.direct/
I’ve been getting used to DD-WRT over an AirPort Extreme. Once Apple dropped the product, I got aNetgear R7000 and took off their stock firmware, and put DD-WRT on. My impression is since No DNS Rebind is disabled by default means Remind is ON by default. Since disabling it in my case caused problems, and re-enabling it brought full functionality back, does this mean Plex, or Roku has solved the rebind issues? I did noticed the extra options mentioned in the closed thread, however, I didn’t enter them, and things still work, so is there a reason to at this point ? I think my challenges has been, not to understand what I’m doing, but what DDWRT calls things, and if they actually do what the setting is called.
When I initially installed DDWRT, things just worked, things apparently broke after I started tweaking settings learning what things did, and what people recommended to have setup.
Many more options than Apple’s Airport, so it’s been a bit of a learning curve, but the router has been rock solid.
When I first saw the problem this morning, I just had the mindset Roku broke something again, as Apple TV, or iPad didn’t have issues. I mainly use InFuse when I want to stream blu-ray content to avoid Plex’s transcoding, but I still use Plex as well.
If DNS Rebind Protetion is enabled you need the exception if you require https with PMS
That’s what threw me initially, the No DNS Rebind setting in DDWRT is Disabled by default, when I enabled it, things stopped working. It’s almost like DD WRT has the habit of doing the opposite of what the setting name is.
I’ll add the command you supplied.
I’m understanding they called the setting ā€œNo DNSRebindā€ because it means you don’t want DNS Rebinding. So, selecting disable means you’re actually turning it on, and selecting Enable means you’re actually disabling Rebinding. I was mainly looking for clarification that I’m understanding the setting correctly.
So, I don’t think in my initial post I suggested disabling rebind. I apologize if the wrong message came across.
Bottom line enable it so the router will not allow DNS rebinding for your own protection on the internet. Add the exception for Plex and you are done.
Enabled and done. Just to confirm, is this how the settings should look now? Thanks
Enable No DNS Rebind
Done, thanks so much. I tested, and things work with a secure connection. I apologize for the mix up. I had gotten one impression of the setting from the DDWRT forums and then a different one here. The enabled no dns rebind + command you gave me works now. When I came posting the solution I found, I came under the impression, there was no official fix yet. Thanks for providing this. Are there any other things I should add when it comes to other devices such as Apple TV, or a Sony BDP, or is the settings given here mainly only needed for Roku ? Thanks again.
It is a setting which affects the server.
It is important for every Plex client (no matter the client type) which is in the same local network as your server, to access said server over an encrypted connection.
Ok, that I understand, it was mainly the DNS rebind that I was a bit confused about.
Here on Plex, the preferred setting is to Enable ā€œNo DNS Rebindā€, and enter the rebind command in extra options. On the DDWRT forums they have a mix of opinions varying from similar to here to saying the latest beta versions of DDWRT (which I am running) handling’s rebind internally so the setting isn’t as big a deal now as it was in older software. So, that’s why I was a bit confused over the setting. Since enabling it broke my server, and disabling it fixed it, I thought maybe when I was messing with settings and enabled the no dns rebind option, that I had made a mistake. Either way, the client seems to work now with the suggested settings here.
Was the setting does is to create an exemption rule.
While ā€˜DNS rebinding protection’ is still activated globally (ā€˜No DNS rebinding’)
it is allowed for the domain plex.direct.
The whole reason for this is, that the DNS server in dd-wrt cannot distinguish Plex’s completely legit activity from a ā€˜DNS rebinding attack’.
Thus the ā€˜DNS rebinding protection’ needs to be disabled for Plex’s domain name.
DNS Rebind Protection is a preference. It works by not allowing a FQDN that resolves to a RFC918 space to connect. However this is exactly what Plex is doing and its not malicious thus the exception using the options field. It does not hurt to have it enabled as its there to generally protect you from DNS hijacking.
See here:
Right, follow completely. Because DDWRT cals the Setting ā€œNO DNS Rebindā€ setting to enable disables global rebind, but the command gives Plex an exception. Setting No Rebind to Disabled, enables global rebind, so the exception isn’t needed, but also puts the network at risk.
I’m straight now with how the setting is labeled and which way to toggle the setting. Thanks for helping clear this up.
I would change the wording here. Disabled No DNS Rebind ALLOWS for DNS Rebinding. Enabled No DNS Rebind PREVENTS it.
OK, with the routing issues taken care of, one more question. How do I access my continue watching list on the newest Plex channel for Roku? by default it’s not visible. Other then that, everything else is working now as expected.
Someone else will need to answer that.
No need, I reset the home screen after fixing the routing problem, and everything came back as expected. Thanks so much, I’m good to go now.
