Fix for Unicode Exception in Scanners.bundle
I have an issue with PMS where the scanners simply stop indexing my files. After tracking it down in the logs, I found plex was running into an infinite loop (re-scanning the same file over and over) and also found python traceback related to unicode exceptions.
I seem to have fixed both problems for myself by editing the following file:
Plug-ins/Scanners.bundle/Contents/Resources/Common/VideoFiles.py
I think this is the original code
 # Make sure we pre-compose.
  name = unicodedata.normalize('NFKC', name.decode('utf-8'))
  name = name.lower()
The exception was on name.decode, so I simply wrapped the line in a try/except and (more importantly) added decoding for ISO-8859 which is what my filenames were.
  try:
  except Exception, e:
    try:
      name = unicodedata.normalize('NFKC', name.decode('iso8859-15'))
      raise e
  name = name.lower()
I know this is a monkey patch but without it my plex server was useless since my files wouldn't be indexed anymore.
I am hoping the devs will integrate this fix for the next version of plex. Maybe the patch should be more generic and done elsewhere ? I do not know. And obviously other unicode codecs should be added if needed.
Thanks for the great software!
helped me a lot, thanks !
