Certain library keeps getting stuck on [0x7fd53e09e840] DEBUG - Adding file for scanner: ""
Server Version#: 1.13.9.5456
Player Version#: 3.71.1
For 1 specific folder/library regardless of the scanner or agent that is used the scan turns into an infinite loop of [0x7fd53e09e840] DEBUG - Adding file for scanner: “”. It’s the only thing in the log files and it’s as if it gets caught on a file or something that just breaks plex. But I’ve tried removing folders etc and it doesn’t make a difference. I don’t know what information to provide but plex can definitely see the folders and my other 8 Libraries work perfectly. I’m pretty sure it’s not a permissions issue but I have no idea what to do. This issue specifically occurred after switching to Ubuntu. The same folder scanned fine on windows
Log files please?
The only reasons a file would keep being added (until point of failure)
  1. Symbolic link to itself
  2. Automatic update enabled and file is being modified / updated / written to by external program.
Plex Media Scanner.1.log (5.0 MB)
Plex Media Scanner.2.log (5.0 MB)
Plex Media Scanner.3.log (5.0 MB)
Plex Media Scanner.4.log (5.0 MB)
Plex Media Scanner.5.log (4.3 MB)
Plex Media Scanner.log (2.7 MB)
These are the scanner logs. They’re all essentially the same thing
  1. Start the scan
  2. Let it finish
  3. Settings - Server - Troubleshooting - Download Logs
  4. Attach the ZIP file
The file system errors and reasons to add to the scanner are not located in the Scanner logs.
Plex Media Server Logs_2018-11-21_19-22-27.zip (2.3 MB)
I haven’t seen it manage to complete the scan before so here is the logs after while it is seemingly stuck. I will also leave it going in case it actually completes
Edit: This is the logs after it’s been trying to scan for around 50 min Plex Media Server Logs_2018-11-21_20-07-47.zip (2.3 MB)
There is corruption in the file system. With this type of corruption of the name, it is very likely there is other corruption of the file / directory pointers too.
in Token (Kleptomanta)
Nov 21, 2018 19:19:01.192 [0x7f1647bff700] DEBUG - DirectoryBrowser: Decoded [L21udC9NeSBQYXNzcG9ydC9NZWRpYS9WaWRlby9KYXBhbmVzZS@jgqLjg4vjg6E=] to [/mnt/My Passport/Media/Video/Japanese(ਸ\E0\E2\F8\E0]
Nov 21, 2018 19:19:01.194 [0x7f1647bff700] ERROR - Couldn't check for the existence of file "/mnt/My Passport/Media/Video/Japanese(ਸ\E0\E2\F8\E0": boost::filesystem::status: Invalid or incomplete multibyte or wide character: "/mnt/My Passport/Media/Video/Japanese(ਸ\E0\E2\F8\E0"
Nov 21, 2018 19:19:01.194 [0x7f165bffe700] DEBUG - Completed: [127.0.0.1:57848] 200 GET /services/browse/L21udC9NeSBQYXNzcG9ydC9NZWRpYS9WaWRlby9KYXBhbmVzZS@jgqLjg4vjg6E=?includeFiles=1 (5 live) GZIP 2ms 350 bytes (pipelined: 8)
Nov 21, 2018 19:19:03.319 [0x7f165c7ff700] DEBUG - Auth: authenticated user 1
Some of what it finds is valid.
Nov 21, 2018 14:45:53.409 [0x7f35c8bf7700] DEBUG - Item 14849 (リトルウィッチアカデミア (2017) - 18 - 空中大戦争スタンシップ) Scanning metadata graphic elements in XML file ""/Info.xml
Nov 21, 2018 14:45:53.412 [0x7f35cc3fe700] DEBUG - Request: [127.0.0.1:41934 (Loopback)] GET /library/metadata/14850/tree (19 live) GZIP Signed-in Token (Kleptomanta)
Nov 21, 2018 14:45:53.415 [0x7f35e8fff700] DEBUG - Completed: [127.0.0.1:41934] 200 GET /library/metadata/14850/tree (18 live) GZIP 3ms 770 bytes
Nov 21, 2018 14:45:53.419 [0x7f35c8bf7700] DEBUG - Loading information from media bundle for part ID 16768 from "/var/lib/plexmediaserver/Library/Application
I presume this is Anime ?
The matter is further compromised by the scanner only seeing bad names here.
Nov 21, 2018 14:43:00.525 [0x7f35e8fff700] DEBUG - Completed: [127.0.0.1:51520] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20%E3%82%BD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%BC%E3%83%88%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3II%20[1080P] (29 live) GZIP 0ms 166 bytes
Nov 21, 2018 14:43:00.528 [0x7f35da3fc700] DEBUG - [Scanners.bundle] Removing file due to plexignore rule (.*\Z(?ms)): /mnt/My Passport/Media/Video/Japanese/���������/������������������������������������II [1080P]/NC/.plexignore
Nov 21, 2018 14:43:00.530 [0x7f35d73f6700] DEBUG - [Scanners.bundle] Removing file due to plexignore rule (.*\Z(?ms)): /mnt/My Passport/Media/Video/Japanese/���������/������������������������������������II [1080P]/NC/[SallySubs] Sword Art Online II - NCED 1 [BD 1080p FLAC] [D4B9767E].mkv
Nov 21, 2018 14:43:00.531 [0x7f35db3fe700] DEBUG - [Scanners.bundle] Removing file due to plexignore rule (.*\Z(?ms)): /mnt/My Passport/Media/Video/Japanese/���������/������������������������������������II [1080P]/NC/[SallySubs] Sword Art Online II - NCED 2 [BD 1080p FLAC] [AF7ACCDA].mkv
Nov 21, 2018 14:43:00.533 [0x7f35d63f4700] DEBUG - [Scanners.bundle] Removing file due to plexignore rule (.*\Z(?ms)): /mnt/My Passport/Media/Video/Japanese/���������/������������������������������������II [1080P]/NC/[SallySubs] Sword Art Online II - NCED 3 [BD 1080p FLAC] [68B9C079].mkv
Nov 21, 2018 14:43:00.535 [0x7f35dbbff700] DEBUG - [Scanners.bundle] Removing file due to plexignore rule (.*\Z(?ms)): /mnt/My Passport/Media/Video/Japanese/���������/������������������������������������II [1080P]/NC/[SallySubs] Sword Art Online II - NCED 4 [BD 1080p FLAC] [2D8F2BAA].mkv
Nov 21, 2018 14:43:00.536 [0x7f35d93fa700] DEBUG - [Scanners.bundle] Removing file due to plexignore rule (.*\Z(?ms)): /mnt/My Passport/Media/Video/Japanese/���������/������������������������������������II [1080P]/NC/[SallySubs] Sword Art Online II - NCOP 1 [BD 1080p FLAC] [E3F06E4A].mkv
Nov 21, 2018 14:43:00.537 [0x7f35d23fc700] DEBUG - [Scanners.bundle] Removing file due to plexignore rule (.*\Z(?ms)): /mnt/My Passport/Media/Video/Japanese/���������/������������������������������������II [1080P]/NC/[SallySubs] Sword Art Online II - NCOP 2 [BD 1080p FLAC] [E94FF177].mkv
Nov 21, 2018 14:43:00.539 [0x7f35d33fe700] DEBUG - [Scanners.bundle] Removing file due to plexignore rule (.*\Z(?ms)): /mnt/My Passport/Media/Video/Japanese/���������/������������������������������������II [1080P]/NC/[SallySubs] Sword Art Online II - NCOP 3 [BD 1080p FLAC] [CA66989F].mkv
Nov 21, 2018 14:43:00.541 [0x7f35d9bfb700] DEBUG - Request: [127.0.0.1:51538 (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20%E3%82%BD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%BC%E3%83%88%E3%83%BB%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3II%20[1080P]%2FNC (29 live) GZIP Signed-in Token (Kleptomanta)
Nov 21, 2018 14:43:00.541 [0x7f35e8fff700] DEBUG - Completed: [127.0.0.1:51538] 200 GET /:/metadata/updateProgressMessage
Notice the directory name characters. This is more indicaton of where your problem is.
The .plexignore is showing us the name of the directory (where the ignore begins) is already problematic.
I cannot be more specific with this level of data.
I see, I presume the corruption isn’t just it not recognizing Japanese characters?
What would you recommend to get rid of the corruption?
Edit: Issue has been resolved. It was because of files with names that were too long. Wasn’t a problem on windows for some reason
