Fix Mismatch - Need a lot of improvement
Server Version#: 4.6.2
I’m trying to fix a mismatch for the movie Split (2016) from M. Night Shyamalan. In the list of mismatch options, there is four options. I cannot tell what is what from the list. I select one, it’s not it, so I click on “Fix Mismatch” again, I cannot tell which match that I had selected, and cannot tell which one I need to click on to get the proper match.
Need to have the list expanded to to have movie posters and a brief description of what is in the list to help know what is what.
Can you post a screenshot of the match choices?
Only a few movies I have come across that have similar names & year. Can be a bit of a pain having to select each match from the list until you get the right one. Be nice to hover over a match to have a brief description popup of the match, Or a button to expand & see the cover & description.
(Not trying to hijack :wink: Just something I would like to see improved too)
I have tried all of the Split 2016, but I cannot tell which is which from what I have selected or which on I have not tried. I still cannot find the correct match.
Here’s the screenshot.
Exactly the issue.
Thanks for the screenshots!
This suggestion might help: Can’t find correct match
Thanks for the suggestion. Finally got the correct movie matched.
The problem is that some (idiot) one keeps adding 2016 to TMDB (US) release records for this movie. (that I keep removing…)
You can also enter TMDB ID: 381288 <----acquired a little clandestinely via snatching it out of the URL:
and in doing so the very first TMDB listing will be the one.
This movie was released in 2017 regardless of what some TMDB users would have us believe.
It’s also interesting to note that if left alone I think this movie matches to “16 Candles”, if I recall correctly. <—something I have keeps wanting to be “16 Candles” and I think it’s this one, but I only find out about it when I move it, or do something else that blows the match.
