Formula Z7:- Text Size?
Hi, when I select a file from my library, before pressing play, the screen provides detail of the movie / tv file, even when viewed on my TV, it is just too small.
Is there a way to increase the text size?
This doesn’t happen on the iOS app, or when viewing Plex on my laptop, just on the android app for my Formula Z7 box.
Any help or advice appreciated.
Could you share an example or screenshot of what content on the pre-play screen is displayed too small?
The below image is a photo from my TV. Unless you walk up to the TV, the text is just too small:
The below image is an extract from Plex web player on my MacBook Pro. Text is the same as other web text, so is really easy to view:
Any ideas then?
Apologies… I must have missed that response.
Got it… no, there’s no way for you to adjust the size of those text elements. – sorry.
Not the answer I wanted, but thanks anyway. Perhaps some glasses eh :smile:
