The dropdown menu for entering tags, completely obscures the thread body. And it’s quite difficult to reliably EXIT this menu.
Android 11.
Android 11.
I see the same issue. It has to do with the small screen size.
You can work around it by tapping twice (with pause) on the “forum section” drop down beside/above.
