Not sure if you need that step, I think its default if found but not 100% sure…
In any case if you did this and enabled Hardware Transcoding in plex it should work can you upload a PMS log or DM it to me? The log should say why it preferred Software Trascoding
Yeah that chip is supported, but when you install the port. That’s all you do is install the port, it doesn’t get used until you load the kernel module with kldload or reboot after adding config lines.
your kernel and ports/pkg are out of sync. if you compile your own kernel you really should compile any kernel modules you use from ports, or stick with the default kernel provided by bsdupdate or whatever it’s called and pkgs. if you build kernels, always rebuild kernel ports at the same time. there are flags to force kernel modules to build if so needed, but they’re not set by default.
if you’re running the default kernel and don’t plan on building a new one, uninstall that port, and pkg install it. if for some reason you need to build a kernel, update source and ports - install new kernel, then install from ports.
you might be fine with just running pkg install as it should delete the conflicting one, then kldload it and check kldstat.
in that case you build the module which uses newer kernel source that what is running so there will be times when it won’t be able to load, also times when it could cause you to crash.
Dec 18, 2018 06:53:19.237 [0x80dc4b000] DEBUG - Codecs: hardware transcoding: testing API vaapi
Dec 18, 2018 06:53:19.237 [0x80dc4b000] ERROR - [FFMPEG] - No VA display found for device: /dev/dri/renderD128.
