Thanks for taking your time to look at the issue.
But, as I said the issue isn’t jail or plex-specific. The issue exists with vainfo or ffmpeg on the host itself, even if running as root.
Summary
root@lrrr:~ # truss vainfo --display drm --device /dev/dri/renderD128
mmap(0x0,131072,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34361999360 (0x800228000)
issetugid() = 0 (0x0)
openat(AT_FDCWD,"/etc/libmap.conf",O_RDONLY|O_CLOEXEC,00) = 3 (0x3)
fstat(3,{ mode=-rw-r--r-- ,inode=20991,size=122,blksize=4096 }) = 0 (0x0)
read(3,"# $FreeBSD: releng/12.0/libexec/"...,122) = 122 (0x7a)
close(3) = 0 (0x0)
open("/usr/local/etc/libmap.d",O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC,0165) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/var/run/ld-elf.so.hints",O_RDONLY|O_CLOEXEC,00) = 3 (0x3)
read(3,"Ehnt\^A\0\0\0\M^@\0\0\0\M^F\^A\0"...,128) = 128 (0x80)
fstat(3,{ mode=-r--r--r-- ,inode=26084,size=518,blksize=4096 }) = 0 (0x0)
pread(3,"/lib:/usr/lib:/usr/lib/compat:/u"...,390,0x80) = 390 (0x186)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libX11.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libX11.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libX11.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libX11.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=78860,size=1311168,blksize=131072 }) = 0 (0x0)
mmap(0x0,4096,PROT_READ,MAP_PRIVATE|MAP_PREFAULT_READ,3,0x0) = 34362130432 (0x800248000)
mmap(0x0,1314816,PROT_NONE,MAP_GUARD,-1,0x0) = 34362134528 (0x800249000)
mmap(0x800249000,688128,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34362134528 (0x800249000)
mmap(0x8002f1000,598016,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0xa8000) = 34362822656 (0x8002f1000)
mmap(0x800383000,24576,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x13a000) = 34363420672 (0x800383000)
mmap(0x800389000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34363445248 (0x800389000)
munmap(0x800248000,4096) = 0 (0x0)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libXext.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libXext.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libXext.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libXext.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=144468,size=76488,blksize=76800 }) = 0 (0x0)
mmap(0x0,81920,PROT_NONE,MAP_GUARD,-1,0x0) = 34363449344 (0x80038a000)
mmap(0x80038a000,24576,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34363449344 (0x80038a000)
mmap(0x800390000,45056,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x6000) = 34363473920 (0x800390000)
mmap(0x80039b000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x11000) = 34363518976 (0x80039b000)
mmap(0x80039d000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34363527168 (0x80039d000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libXfixes.so.3",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libXfixes.so.3",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libXfixes.so.3",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libXfixes.so.3",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=162648,size=32208,blksize=32256 }) = 0 (0x0)
mmap(0x0,32768,PROT_NONE,MAP_GUARD,-1,0x0) = 34363531264 (0x80039e000)
mmap(0x80039e000,8192,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34363531264 (0x80039e000)
mmap(0x8003a0000,12288,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x2000) = 34363539456 (0x8003a0000)
mmap(0x8003a3000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x5000) = 34363551744 (0x8003a3000)
mmap(0x8003a5000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34363559936 (0x8003a5000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libva-x11.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libva-x11.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libva-x11.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libva-x11.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=187743,size=27256,blksize=27648 }) = 0 (0x0)
mmap(0x0,32768,PROT_NONE,MAP_GUARD,-1,0x0) = 34363564032 (0x8003a6000)
mmap(0x8003a6000,8192,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34363564032 (0x8003a6000)
mmap(0x8003a8000,12288,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x2000) = 34363572224 (0x8003a8000)
mmap(0x8003ab000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x5000) = 34363584512 (0x8003ab000)
mmap(0x8003ad000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34363592704 (0x8003ad000)
__sysctl(0x7fffffffd0d8,0x2,0x80022761c,0x7fffffffd0e0,0x0,0x0) = 0 (0x0)
__sysctl(0x7fffffffd0d8,0x2,0x80022771c,0x7fffffffd0e0,0x0,0x0) = 0 (0x0)
__sysctl(0x7fffffffd0d8,0x2,0x80022781c,0x7fffffffd0e0,0x0,0x0) = 0 (0x0)
__sysctl(0x7fffffffd0d8,0x2,0x80022791c,0x7fffffffd0e0,0x0,0x0) = 0 (0x0)
__sysctl(0x7fffffffd0d8,0x2,0x800227a1c,0x7fffffffd0e0,0x0,0x0) = 0 (0x0)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libdrm.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libdrm.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libdrm.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libdrm.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=184503,size=84648,blksize=84992 }) = 0 (0x0)
mmap(0x0,90112,PROT_NONE,MAP_GUARD,-1,0x0) = 34363596800 (0x8003ae000)
mmap(0x8003ae000,28672,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34363596800 (0x8003ae000)
mmap(0x8003b5000,49152,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x7000) = 34363625472 (0x8003b5000)
mmap(0x8003c1000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x13000) = 34363674624 (0x8003c1000)
mmap(0x8003c3000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34363682816 (0x8003c3000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libva-drm.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libva-drm.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libva-drm.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libva-drm.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=187734,size=15128,blksize=15360 }) = 0 (0x0)
mmap(0x0,16384,PROT_NONE,MAP_GUARD,-1,0x0) = 34363686912 (0x8003c4000)
mmap(0x8003c4000,4096,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34363686912 (0x8003c4000)
mmap(0x8003c5000,4096,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x1000) = 34363691008 (0x8003c5000)
mmap(0x8003c6000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x2000) = 34363695104 (0x8003c6000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libva-wayland.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libva-wayland.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libva-wayland.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libva-wayland.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=187740,size=23640,blksize=24064 }) = 0 (0x0)
mmap(0x0,24576,PROT_NONE,MAP_GUARD,-1,0x0) = 34363703296 (0x8003c8000)
mmap(0x8003c8000,8192,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34363703296 (0x8003c8000)
mmap(0x8003ca000,8192,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x2000) = 34363711488 (0x8003ca000)
mmap(0x8003cc000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x4000) = 34363719680 (0x8003cc000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libva.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libva.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libva.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libva.so.2",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=187746,size=159912,blksize=131072 }) = 0 (0x0)
mmap(0x0,163840,PROT_NONE,MAP_GUARD,-1,0x0) = 34363727872 (0x8003ce000)
mmap(0x8003ce000,57344,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34363727872 (0x8003ce000)
mmap(0x8003dc000,94208,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0xe000) = 34363785216 (0x8003dc000)
mmap(0x8003f3000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x25000) = 34363879424 (0x8003f3000)
mmap(0x8003f5000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34363887616 (0x8003f5000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libwayland-client.so.0",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libwayland-client.so.0",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libwayland-client.so.0",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libwayland-client.so.0",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=139979,size=144904,blksize=131072 }) = 0 (0x0)
mmap(0x0,81920,PROT_NONE,MAP_GUARD,-1,0x0) = 34363891712 (0x8003f6000)
mmap(0x8003f6000,32768,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34363891712 (0x8003f6000)
mmap(0x8003fe000,32768,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x8000) = 34363924480 (0x8003fe000)
mmap(0x800406000,12288,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x10000) = 34363957248 (0x800406000)
mmap(0x800409000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34363969536 (0x800409000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libthr.so.3",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=20729,size=131824,blksize=131072 }) = 0 (0x0)
mmap(0x0,176128,PROT_NONE,MAP_GUARD,-1,0x0) = 34363973632 (0x80040a000)
mmap(0x80040a000,49152,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34363973632 (0x80040a000)
mmap(0x800416000,69632,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0xc000) = 34364022784 (0x800416000)
mmap(0x800427000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x1d000) = 34364092416 (0x800427000)
mmap(0x800429000,49152,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34364100608 (0x800429000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libc.so.7",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=20697,size=1949672,blksize=131072 }) = 0 (0x0)
mmap(0x0,4141056,PROT_NONE,MAP_GUARD,-1,0x0) = 34364149760 (0x800435000)
mmap(0x800435000,491520,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34364149760 (0x800435000)
mmap(0x8004ad000,1331200,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x78000) = 34364641280 (0x8004ad000)
mmap(0x8005f2000,61440,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x1bd000) = 34365972480 (0x8005f2000)
mmap(0x800601000,2256896,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34366033920 (0x800601000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libxcb.so.1",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libxcb.so.1",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libxcb.so.1",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libxcb.so.1",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=75080,size=162640,blksize=131072 }) = 0 (0x0)
mmap(0x0,167936,PROT_NONE,MAP_GUARD,-1,0x0) = 34368290816 (0x800828000)
mmap(0x800828000,86016,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34368290816 (0x800828000)
mmap(0x80083d000,69632,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x15000) = 34368376832 (0x80083d000)
mmap(0x80084e000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x26000) = 34368446464 (0x80084e000)
mmap(0x800850000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34368454656 (0x800850000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libm.so.5",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=20716,size=217024,blksize=131072 }) = 0 (0x0)
mmap(0x0,204800,PROT_NONE,MAP_GUARD,-1,0x0) = 34368458752 (0x800851000)
mmap(0x800851000,69632,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34368458752 (0x800851000)
mmap(0x800862000,122880,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x11000) = 34368528384 (0x800862000)
mmap(0x800880000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x2f000) = 34368651264 (0x800880000)
mmap(0x800882000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34368659456 (0x800882000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libffi.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libffi.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libffi.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libffi.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=382202,size=35624,blksize=35840 }) = 0 (0x0)
mmap(0x0,40960,PROT_NONE,MAP_GUARD,-1,0x0) = 34368663552 (0x800883000)
mmap(0x800883000,8192,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34368663552 (0x800883000)
mmap(0x800885000,20480,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x2000) = 34368671744 (0x800885000)
mmap(0x80088a000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x7000) = 34368692224 (0x80088a000)
mmap(0x80088c000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34368700416 (0x80088c000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libepoll-shim.so.0",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libepoll-shim.so.0",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libepoll-shim.so.0",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libepoll-shim.so.0",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=135997,size=23096,blksize=23552 }) = 0 (0x0)
mmap(0x0,28672,PROT_NONE,MAP_GUARD,-1,0x0) = 34368704512 (0x80088d000)
mmap(0x80088d000,8192,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34368704512 (0x80088d000)
mmap(0x80088f000,8192,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x2000) = 34368712704 (0x80088f000)
mmap(0x800891000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x4000) = 34368720896 (0x800891000)
mmap(0x800893000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34368729088 (0x800893000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/librt.so.1",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/librt.so.1",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=20848,size=27384,blksize=27648 }) = 0 (0x0)
mmap(0x0,32768,PROT_NONE,MAP_GUARD,-1,0x0) = 34368733184 (0x800894000)
mmap(0x800894000,12288,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34368733184 (0x800894000)
mmap(0x800897000,8192,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x3000) = 34368745472 (0x800897000)
mmap(0x800899000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x5000) = 34368753664 (0x800899000)
mmap(0x80089b000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34368761856 (0x80089b000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libXau.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libXau.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libXau.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libXau.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=74674,size=18552,blksize=18944 }) = 0 (0x0)
mmap(0x0,20480,PROT_NONE,MAP_GUARD,-1,0x0) = 34368765952 (0x80089c000)
mmap(0x80089c000,4096,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34368765952 (0x80089c000)
mmap(0x80089d000,4096,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x1000) = 34368770048 (0x80089d000)
mmap(0x80089e000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x2000) = 34368774144 (0x80089e000)
mmap(0x8008a0000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34368782336 (0x8008a0000)
close(3) = 0 (0x0)
openat(AT_FDCWD,"/lib/libXdmcp.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/libXdmcp.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/lib/compat/libXdmcp.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) ERR#2 'No such file or directory'
openat(AT_FDCWD,"/usr/local/lib/libXdmcp.so.6",O_RDONLY|O_CLOEXEC|O_VERIFY,00) = 3 (0x3)
fstat(3,{ mode=-rwxr-xr-x ,inode=74879,size=31696,blksize=31744 }) = 0 (0x0)
mmap(0x0,28672,PROT_NONE,MAP_GUARD,-1,0x0) = 34368786432 (0x8008a1000)
mmap(0x8008a1000,12288,PROT_READ,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34368786432 (0x8008a1000)
mmap(0x8008a4000,8192,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x3000) = 34368798720 (0x8008a4000)
mmap(0x8008a6000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x5000) = 34368806912 (0x8008a6000)
close(3) = 0 (0x0)
mprotect(0x800387000,8192,PROT_READ) = 0 (0x0)
mprotect(0x80039c000,4096,PROT_READ) = 0 (0x0)
mprotect(0x8003a4000,4096,PROT_READ) = 0 (0x0)
mprotect(0x8003ac000,4096,PROT_READ) = 0 (0x0)
mprotect(0x8003c2000,4096,PROT_READ) = 0 (0x0)
mprotect(0x8003c7000,4096,PROT_READ) = 0 (0x0)
mprotect(0x8003cd000,4096,PROT_READ) = 0 (0x0)
mprotect(0x8003f4000,4096,PROT_READ) = 0 (0x0)
mprotect(0x800407000,8192,PROT_READ) = 0 (0x0)
mprotect(0x800428000,4096,PROT_READ) = 0 (0x0)
munmap(0x80023f000,36864) = 0 (0x0)
mmap(0x0,200704,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34368815104 (0x8008a8000)
mprotect(0x8005f8000,36864,PROT_READ) = 0 (0x0)
mprotect(0x80084f000,4096,PROT_READ) = 0 (0x0)
mprotect(0x800881000,4096,PROT_READ) = 0 (0x0)
mprotect(0x80088b000,4096,PROT_READ) = 0 (0x0)
mprotect(0x800892000,4096,PROT_READ) = 0 (0x0)
mprotect(0x80089a000,4096,PROT_READ) = 0 (0x0)
mprotect(0x80089f000,4096,PROT_READ) = 0 (0x0)
mprotect(0x8008a7000,4096,PROT_READ) = 0 (0x0)
mprotect(0x205000,4096,PROT_READ) = 0 (0x0)
sigprocmask(SIG_BLOCK,{ SIGHUP|SIGINT|SIGQUIT|SIGKILL|SIGPIPE|SIGALRM|SIGTERM|SIGURG|SIGSTOP|SIGTSTP|SIGCONT|SIGCHLD|SIGTTIN|SIGTTOU|SIGIO|SIGXCPU|SIGXFSZ|SIGVTALRM|SIGPROF|SIGWINCH|SIGINFO|SIGUSR1|SIGUSR2 },{ }) = 0 (0x0)
sigprocmask(SIG_SETMASK,{ },0x0) = 0 (0x0)
readlink("/etc/malloc.conf",0x7fffffffd720,1024) ERR#2 'No such file or directory'
__sysctl(0x7fffffffd688,0x2,0x7fffffffd684,0x7fffffffd690,0x0,0x0) = 0 (0x0)
mmap(0x0,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34362093568 (0x80023f000)
madvise(0x80023f000,4096,MADV_FREE) = 0 (0x0)
munmap(0x80023f000,4096) = 0 (0x0)
mmap(0x0,2097152,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369015808 (0x8008d9000)
munmap(0x8008d9000,2097152) = 0 (0x0)
mmap(0x0,4190208,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369015808 (0x8008d9000)
munmap(0x8008d9000,1208320) = 0 (0x0)
munmap(0x800c00000,884736) = 0 (0x0)
mmap(0x0,32768,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34362093568 (0x80023f000)
mmap(0x0,4194304,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34372321280 (0x800c00000)
mmap(0x0,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34362126336 (0x800247000)
mmap(0x0,12288,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369015808 (0x8008d9000)
mmap(0x0,12288,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369028096 (0x8008dc000)
mmap(0x0,12288,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369040384 (0x8008df000)
__sysctl(0x7fffffffdb60,0x2,0x80042a040,0x7fffffffdb78,0x0,0x0) = 0 (0x0)
getrlimit(RLIMIT_STACK,{ cur=536870912,max=536870912 }) = 0 (0x0)
__sysctl(0x7fffffffda60,0x2,0x7fffffffdab0,0x7fffffffdaa8,0x80040a3cb,0xd) = 0 (0x0)
__sysctl(0x7fffffffdab0,0x3,0x8004340b0,0x7fffffffdb78,0x0,0x0) = 0 (0x0)
mmap(0x0,20480,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369052672 (0x8008e2000)
mmap(0x0,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34362130432 (0x800248000)
thr_self(0x8008e2000) = 0 (0x0)
mmap(0x7fffdfffe000,4096,PROT_NONE,MAP_ANON,-1,0x0) = 140736951476224 (0x7fffdfffe000)
rtprio_thread(RTP_LOOKUP,102846,0x7fffffffdb38) = 0 (0x0)
sigaction(SIGTHR,{ 0x80041ca40 SA_SIGINFO ss_t },0x0) = 0 (0x0)
sigprocmask(SIG_UNBLOCK,{ },0x0) = 0 (0x0)
_umtx_op(0x7fffffffdb40,UMTX_OP_WAKE,0x1,0x0,0x0) = 0 (0x0)
mprotect(0x0,0,PROT_NONE) = 0 (0x0)
getpid() = 68765 (0x10c9d)
sigprocmask(SIG_BLOCK,{ SIGHUP|SIGINT|SIGQUIT|SIGILL|SIGTRAP|SIGABRT|SIGEMT|SIGFPE|SIGKILL|SIGBUS|SIGSEGV|SIGSYS|SIGPIPE|SIGALRM|SIGTERM|SIGURG|SIGSTOP|SIGTSTP|SIGCONT|SIGCHLD|SIGTTIN|SIGTTOU|SIGIO|SIGXCPU|SIGXFSZ|SIGVTALRM|SIGPROF|SIGWINCH|SIGINFO|SIGUSR1|SIGUSR2 },{ }) = 0 (0x0)
getcontext(0x7fffffffd640) = 0 (0x0)
sysarch(AMD64_GET_XFPUSTATE,0x7fffffffd608) = 0 (0x0)
openat(AT_FDCWD,"/dev/dri/renderD128",O_RDWR,00) = 3 (0x3)
fstat(3,{ mode=crw-rw---- ,inode=620,size=0,blksize=4096 }) = 0 (0x0)
mmap(0x0,12288,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369073152 (0x8008e7000)
mmap(0x0,12288,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369085440 (0x8008ea000)
mmap(0x0,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369097728 (0x8008ed000)
mmap(0x0,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369101824 (0x8008ee000)
mmap(0x0,28672,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369105920 (0x8008ef000)
mmap(0x0,28672,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369134592 (0x8008f6000)
mmap(0x0,20480,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369163264 (0x8008fd000)
mmap(0x0,12288,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369183744 (0x800902000)
open("/etc/libva.conf",O_RDONLY,0666) ERR#2 'No such file or directory'
libva info: VA-API version 1.3.0
write(2,"libva info: VA-API version 1.3.0"...,33) = 33 (0x21)
ioctl(3,0xc0406400 { IORW 0x64('d'), 0, 64 },0x800248040) = 0 (0x0)
mmap(0x0,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34369196032 (0x800905000)
ioctl(3,0x40046402 { IOR 0x64('d'), 2, 4 },0x7fffffffe5a0) ERR#13 'Permission denied'
libva info: va_getDriverName() returns 1
write(2,"libva info: va_getDriverName() r"...,41) = 41 (0x29)
libva error: va_getDriverName() failed with operation failed,driver_name=i965
write(2,"libva error: va_getDriverName() "...,78) = 78 (0x4e)
vaInitialize failed with error code 1 (operation failed),exit
write(2,"vaInitialize failed with error c"...,62) = 62 (0x3e)
close(3) = 0 (0x0)
exit(0x3)
process exit, rval = 3
