Fullscreen UI without Tablet Mode
Since you stopped the app from opening in fullscreen, there doesn’t seem to be a way to get the main UI to use the entire monitor without enabling Tablet Mode in windows.
I request some way to do this, as well as a way to hide the bottom command bar. That way, the UI can utilize the maximum amount of screen real estate.
Double-click anywhere in the app (that isn’t a button).
How would that work when using a remote rather than a keyboard? I’m running the beta app on a Lenovo HDMI stick connected to my TV and using flirc and a harmony remote and can’t find a way to get the app in full screen. Also, double clicking only works when the app is not fully maximised. I’d happy if the app would remember that it was full screen but currently it opens not full screen so I have to take out a keyboard to get it to full screen.
Double clicking empty space in the UI did not make the app fullscreen.
I just wish it had the option is all. If it caused issues you could just simply not enable it.
For me I can double-click when a video is playing to switch it into full screen, but not in other parts of the app. There’s also a double-ended arrow available in the video’s OSD. After it gets set, the rest of the app stays full screen, even after an exit & re-run.
