Getting an error when accessing the pre-play screen - read this?
New commit has been added to github that should solve the preplay screen problem with firmware 5.0.2 and 5.1, could somebody with this problem please test it and let me know if it's solved, thanks.
Hi Roidy
It works on mine !! atv2 running 5.02
finally i have the small episode/ movie info window where i can choose the subtitles/ audio and can play things from the "select" button
only thing still missing is the popup window to select from the beginning or where you left off last time ...
in my case the kid has annoying habbit to stop a movie when the movie ends aka when the credits start... but this makes most of my movies start at that point when watching with plexconnect... or am i missing something ?
Umm... I didn't realize the resume screen was missing in the older firmwares. The best fix I can offer at the moment is to edit PlayVideo.xml and remove the entire line, this will make all video always play from the start. I'll try and look for a better fix after we merge in elan's code and lock down the pre 5.2 firmware version.
hi Roidy
made small video for you
https://www.dropbox.com/s/rehe0znuijs7dq8/20130615_184641.mp4
so you see what happens
Yep, as I suspected, on the new firmware when you play a video that has a resume point set it automatically displays a resume screen like so:-
This seems to be missing on the old 5.0.2 firmware. As I said as a temporary fix you can edit PlayVideo.xml and remove the line, this will make all videos play from the beginning. Once the code merge is complete I'll go back and add a resume screen like the one above to the 5.0.2 code base.
