Well, & or ?... I guess we are not so much standard :-)
With the Preplay we currently see a little issue on our side as well: If your metadata doesn't provide director, genre and stuff, it might fail. We are working on it...
Try to play your show directly - press Play/Pause instead of Select. That should work...
I have the same problem. Try to add each video to one folder, and rename with the convention. Ex:
(Folder) Season 1
(Inside folder) Lost - S01E04 - Name of Episode
It's strange, but works for me.
I tried using play instead of select and I get a different error.
On Screen: "An error occurred loading this content - Try again later"
From the plexconnect log:
>> UPDATE: turning OFF "Force Direct Play" makes it work as long as I press play instead of select!
cool.. was just one of the several things I tried to get it to work.
Now if pms releases their update so we can have surround sound it'll be awesome.
It is already out for PlexPass users, hopefully it will not be too long before the public release.
/me goes to get plexpass
I can confirm that now that I have my atv at the latest firmware (5.2.1) I can see all the metadata by pressing select on the remote and all is working great.. :D
The same here. Update from 5.0.2 to 5.2.1 fix the problem.
Where did you turn this option OFF?
aTV->PlexConnect->Settings->...
Boy, I really don't want to be an idiot about this but I'm not following. Do you mean from the physical ATV menu?
yes. in the aTV, using your remote.
go to "trailers app" aka PlexConnect, find your way to settings...
Ah, ok - in the Trailers App, I only have 4 options: Library, Channels, Music, Photos... so that's where my problem lies.
Uh... OLD VERSION.
Where did you get that?
Weird.... github about an hour ago. Let me try this all over again and see what happens... weird.
Yup, re-installed it and now I see the "settings" section - thanks!!
