I currently have good internet speeds by my ISP (450 down/30 up) but when I turn on my VPN (Windscribe), it goes to 120/12. So far, Windscribe is the only VPN I have heard of that works with Plex to allow external connections.
My ISP is offering Gig speed internet but unless I can find a VPN that works with Plex that also allows something even close to Gig speed, their no need to do so.
Does anyone know of a VPN that both has the speed and works with Plex and port forwarding and external access?
Thanks for the info. I have no idea what an edge device is or one that uses AES-NI. Can you link to some examples? It sounds like you are saying to get a physical “thing” that sits between your modem/router and PC and it handles the encryption.
That sounds good, if I am right. Does it work with Plex and port forwarding? Sorry if these are dumb questions.
