Remove a section
I'd like to remove the Home Movies section from Global Slideshow (leaving it on for Movies and TV Shows), but I can only find a basic on/off for the whole thing.
+1
I’d love to be able to control which sections are included in the automatic slideshow. However, I guess this would have to be an option in the manager itself; I’m imagining a simple ‘include in slideshow’ checkbox within each channel.
A simpler solution in the short-term, and one I’d be happy with, would be a setting at the client level to turn off the rotating slideshow completely. It can be very distracting when the TV is on, but not in use.
In the latest release of PHT you can turn it off in the settings.
(You could before as well, but it didn’t do much)
Are there any plans to allow defining our own folder with images to be used for section? In other words, define your own slideshow images in web manager so that client could use those in home slideshow?
We talked about that internally, but it’s not as easy as it seems for several reasons. We will consider it for later.
Many thanks for feedback. Hope you will manage to find a solution somehow.
If it would prove difficult, I'll be happy to at least define one background per section (like in cocoa manager) so that kids can find their stuff easily. I have them set currently via cocoa manager, but Mediastream does not show them.
Thanks.
+1 This would be great
