i think i found a problem with the search page. If i search for something i con not go back to the startmenu. DOes somebody else have the same problem? I use rasplex over CEC and the back button runs fine in other windows, only in search it makes Problems.
+1, even though I just tried with HDMI CEC, didn't with a keyboard. Maybe it's related
Ive tried without hdmi cec, but without a keyboard. I tried a wmc remote and iR
Yeah i could reproduce this, it seems that the keyboard key which will allow exiting this screen is backspace.
I'm not a skin expert so not sure why we have this specific behaviour on this screen.
I hope someone can change it because it is bad that we can not leave this menu with the same key with that we can leave the other menus.
yea, only solution for me is to reboot the pi. Just dont press the search button by accident until thats fixed :P
Reboot is my solution too but i want to use this function sometimes and do not want to restart ;)
I get this also - I had a look on the rasplex trello project, can’t find this as a registered bug.
How do we get this on the bug list so it gains some focus?
Why not just use the xbmc Remote App for smartphones and tap “back” instead of rebooting your pi?
Good point, but it’s a bit silly to need to use two different remotes to gain access to a fairly basic feature.
Isn’t the best solution to fix the actual problem? I understand this to be a skin issue? If so, how do we get this in front of someone that can resolve it?
