Google drive share drive
Server-Linux Ubuntu 18.04
hello I would not be wrong but until a few years ago it was possible to add folders in the plex library that are part of google drive-share drive
I am a user with plex pass
i have so many files in google drive share drive but i can’t find a suitable configuration
Do you have any guide to identify the drive?
the only way I know is to use rclone.
  1. FUSE-mount the rclone drive through the rclone app
  2. Set permissions on mount points (allow recursive read)
  3. Point PMS at the appropriate mount point / sub directory.
HI
Thank you for your answer
i tried with rclone but it sees me google drive not the share drive so the shared disks
This?
I finally managed to get it to work
the only thing that if I restart the server I have to mount the script again with the command rclone mount mygdrive: ~/gdrive/
Do you have any guide or idea on how I can fix it??
thank you very much for your cooperation
