using your updated image I can also confirm that the color flashes are gone and hw transcoding works normal on Ryzen 5900HX with integrated Vega 8 graphics.
@hexeth you think you can build a mod for the lsio image? would love to verify that it works and use an image thats maintained
Isnt the Vega8 integrated graphics on the 5900HX a Zen 3 APU?`
mauimauers new image works fine for me without artifacts and with hw transcoding working correctly (dashboard shows hw transcoding and cpu usage is below 10% which comes from other apps running on the box)
Hi @mauimauer, this update broke hardware transcoding for me on Unraid 6.9.2. Currently have a 5700G and it worked fine earlier. I’m thinking it might have to do with the older version of unraid but can anyone else confirm? Thanks!
Since making the docker container, I switched to a proxmox cluster, and no longer run Plex in a docker environment.
It seems to me though that you could just use the custom-cont-init.d bind with a bash script that copies the files over. All the required files are listed in the docker file
I tried building and running that Dockerfile locally and prevented plex from updating but I still get artifacts after enabling hw transcoding.
@mauimauer
I would love to take these modifications and create an image layer that can be used as “mod” ( GitHub - linuxserver/docker-mods: Documentation and Examples of base container modifications )for the plex image linuxserver.io so me and others can enjoy a maintained and updated version of plex.
Unfortunately I am not sure what could be “missing” as your Dockerfile is building it from scratch while I just need the modifications needed for an existing plex deployment to serve an image layer.
If anyone else knows, please chime in and I will try to get this in as a mod for the plex lsio image…
The issue is that the linuxserver container still has Mesa 22.0.5 I’m guessing. I don’t think they have backported the fix from 22.2. That’s because 22.0.5 is what Ubuntu 22.04 provides. I’m not really sure how to get them on the latest version of Mesa or if you could even do that through a plugin.
those are already installed, its part of what hexeth posted
mesa is 22.4 as you can see above but the “vainfo: VA-API version: 1.14 (libva 2.12.0)”
is one version behind
he forked it from a project that uses lsio as base and then adds the necessary drivers but it has artifacts
now judging from vainfo i could try updating the VA-API version from 2.12 to 2.15 but I dont know how yet
the oibaf PPA has libva but it doesn’t have a backport to 22.04. For testing purposes, you could try updating the Ubuntu in the container to 22.10 Kinetic which has 2.16 in the oibaf PPA.
