Plex 1.29.0.6244 Hardware Transcoding no longer working
Server Version#: 1.29.0.6244
I’ve just completed upgrades and migrations to Rocky Linux 8.6. After completing the upgrade and updating Plex I now see that Hardware Transcoding for my Quadro P400 is no longer working.
Nvidia 515.76
The system is stable, running normally, and test with Nvidia Docker container appears to show the driver is installed correctly and available. Nvidia-SMI works just fine and the nouveau driver is no where in sight.
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Codecs: testing h264_vaapi (encoder)
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Codecs: hardware transcoding: testing API vaapi
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - Trying to use DRM render node for device 0.
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - libva: VA-API version 1.15.0
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - libva: Trying to open /usr/lib/plexmediaserver/lib/dri/nvidia_drv_video.so
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - libva: va_openDriver() returns -1
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] ERROR - [Req#37599/Transcode] [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: I/O error
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Could not create hardware context for h264_vaapi
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Codecs: testing h264_nvenc (encoder)
Oct 07, 2022 11:04:32.623 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Codecs: hardware transcoding: testing API nvenc
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded lib: libcuda.so.1
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuInit
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetCount
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetAttribute
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetName
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceComputeCapability
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxCreate_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxSetLimit
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxPushCurrent_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxPopCurrent_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxDestroy_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemAlloc_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemAllocPitch_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemsetD8Async
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemFree_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemcpy2D_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemcpy2DAsync_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGetErrorName
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGetErrorString
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxGetDevice
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxRetain
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxRelease
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxSetFlags
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxGetState
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxReset
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamCreate
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamQuery
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamSynchronize
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamDestroy_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamAddCallback
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventCreate
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventDestroy_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventSynchronize
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventQuery
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventRecord
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLaunchKernel
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLinkCreate
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLinkAddData
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLinkComplete
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLinkDestroy
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuModuleLoadData
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuModuleUnload
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuModuleGetFunction
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuTexObjectCreate
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuTexObjectDestroy
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGLGetDevices_v2
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsGLRegisterImage
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnregisterResource
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsMapResources
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnmapResources
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsSubResourceGetMappedArray
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetUuid
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuImportExternalMemory
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDestroyExternalMemory
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedBuffer
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedMipmappedArray
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayGetLevel
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayDestroy
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuImportExternalSemaphore
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDestroyExternalSemaphore
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuSignalExternalSemaphoresAsync
Oct 07, 2022 11:04:32.624 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuWaitExternalSemaphoresAsync
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - CUDA texture alignment: 512
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded lib: libcuda.so.1
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuInit
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetCount
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetAttribute
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetName
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceComputeCapability
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxCreate_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxSetLimit
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxPushCurrent_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxPopCurrent_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxDestroy_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemAlloc_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemAllocPitch_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemsetD8Async
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemFree_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemcpy2D_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMemcpy2DAsync_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGetErrorName
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGetErrorString
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuCtxGetDevice
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxRetain
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxRelease
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxSetFlags
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxGetState
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDevicePrimaryCtxReset
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamCreate
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamQuery
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamSynchronize
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamDestroy_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuStreamAddCallback
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventCreate
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventDestroy_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventSynchronize
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventQuery
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuEventRecord
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLaunchKernel
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLinkCreate
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLinkAddData
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLinkComplete
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuLinkDestroy
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuModuleLoadData
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuModuleUnload
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuModuleGetFunction
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuTexObjectCreate
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuTexObjectDestroy
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGLGetDevices_v2
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsGLRegisterImage
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnregisterResource
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsMapResources
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnmapResources
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuGraphicsSubResourceGetMappedArray
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDeviceGetUuid
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuImportExternalMemory
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDestroyExternalMemory
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedBuffer
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedMipmappedArray
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayGetLevel
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayDestroy
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuImportExternalSemaphore
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuDestroyExternalSemaphore
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuSignalExternalSemaphoresAsync
Oct 07, 2022 11:04:33.218 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: cuWaitExternalSemaphoresAsync
Oct 07, 2022 11:04:33.293 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded lib: libnvidia-encode.so.1
Oct 07, 2022 11:04:33.293 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: NvEncodeAPICreateInstance
Oct 07, 2022 11:04:33.293 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] [FFMPEG] - Loaded sym: NvEncodeAPIGetMaxSupportedVersion
Oct 07, 2022 11:04:33.293 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - Loaded Nvenc version 11.1
Oct 07, 2022 11:04:33.293 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - Nvenc initialized successfully
Oct 07, 2022 11:04:33.320 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - Nvenc unloaded
Oct 07, 2022 11:04:33.354 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Codecs: testing h264 (decoder) with hwdevice vaapi
Oct 07, 2022 11:04:33.354 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - Rescanning for external libs: '/home/plex/Plex\ Media\ Server/Codecs/c4efa15-4369-linux-x86_64/'
Oct 07, 2022 11:04:33.354 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Codecs: hardware transcoding: testing API vaapi
Oct 07, 2022 11:04:33.354 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - Trying to use DRM render node for device 0.
Oct 07, 2022 11:04:33.355 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - libva: VA-API version 1.15.0
Oct 07, 2022 11:04:33.355 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - libva: Trying to open /usr/lib/plexmediaserver/lib/dri/nvidia_drv_video.so
Oct 07, 2022 11:04:33.355 [0x7f31116fbb00] VERBOSE - [Req#37599/Transcode] [FFMPEG] - libva: va_openDriver() returns -1
Oct 07, 2022 11:04:33.355 [0x7f31116fbb00] ERROR - [Req#37599/Transcode] [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Oct 07, 2022 11:04:33.355 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: I/O err
or
Oct 07, 2022 11:04:33.355 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Could not create hardware context for h264
Oct 07, 2022 11:04:33.355 [0x7f31116fbb00] DEBUG - [Req#37599/Transcode] Codecs: testing h264 (decoder) with hwdevice nvdec
→ /usr/lib/plexmediaserver/lib/dri/nvidia_drv_video.so
This file doesn’t exists and even after installing libva-vdpau-driver to the system Plex still appears to be looking for its own copy.
Transcode stopped working for me after Plex upgrade yesterday on Ubuntu.
