Got thousands of "Caught a system exception setting up WebSocket, ignoring."
Server Version#: 1.32.6.7557
Sep 27, 2023 06:40:16.989 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:40:51.677 [23223575665464] Warnung — [Req#327] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Sep 27, 2023 06:40:51.677 [23223575665464] Warnung — [Req#327] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Sep 27, 2023 06:40:51.677 [23223575665464] Warnung — [Req#327] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Sep 27, 2023 06:40:53.934 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:40:53.934 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:40:53.936 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:40:53.936 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:40:53.996 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:40:53.996 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:40:53.999 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:40:53.999 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:40:59.107 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:40:59.107 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:40:59.117 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:40:59.117 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:41:19.188 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:41:19.188 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:41:22.269 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:41:22.270 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:42:19.283 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:42:19.283 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:42:22.124 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:42:22.124 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:42:22.347 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:42:22.347 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:44:24.552 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:44:24.552 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:44:27.377 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:44:27.377 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
Sep 27, 2023 06:44:27.466 [23223575665464] Warnung — WebSocket: Request doesn't look like upgrade request (, close)
Sep 27, 2023 06:44:27.466 [23223575665464] Warnung — Caught a system exception setting up WebSocket, ignoring.
This is a small excerpt of messages I receive in the log. Should I worry? I’m asking because in my mind there shouldn’t be such messages in that short time frame?!
My server is behind a reverse proxy if that matters.
Thanks!
Which Linux distro and version is this?
Would it be possible to get the full DEBUG logs ZIP file ?
I do suspect there’s a proxy problem.
It’s running in docker within unraid.
Check PM
Thank you! :slight_smile:
I have sent you a PM.
My PMs are not open
Do the logs you’re sending me have the websocket messages in them or are you seeing system messages?
