So Does the official plex for unraid not support GPU transcoding ?
If so is there any official setup topic for it.
Check the Unraid forums. Everything is explained there.
I did so and nothing seems explained there. beside some old post with no official reply.
Or
Do you mean the official unraid forums as at limetech ?
You have to use this:
Best is probably also to use the docker image by linuxserver.io for Plex itself.
Cheers. It was the one i used, I changed in the hopes that the official would be better, but i guess not,
Better in terms of what?
