GPU Used to Work, Now Not! 8-(
Server Version#:1.18.8.2527
Hi All,
My Platform runs on VMWare 6.7, With NVIDIA P2000 as GPU, Running with GPU used to work
i noticed in the past 2 to 3 days (possible it started before) that i get no longer HW encoding.
Use Hardware Acceleration is selected.
What line should i search in the logs that confirm Plex uses the hardware acceleration?
Will answer to myself :sunglasses:
System was upgraded, New Plex require new NVIDIA Drivers,
Upgraded, Solved!
Bonus: Removed Restriction on Maximum Number of Simultaneous NVENC Sessions
imposed by Nvidia to consumer-grade GPUs.
(GitHub - keylase/nvidia-patch: This patch removes restriction on maximum number of simultaneous NVENC video encoding sessions imposed by Nvidia to consumer-grade GPUs.)
My apologies for getting back here to late. (TMDB issues)
Yes. 418.30 or above are the required drivers.
This may change again but for now 418.30 is the minimum (as of 1.17.0)
Engineering has a transcoder update in testing at this time.
