GUI Enhancement embedded?
Let me affirm this to you, it may be indeed more than possible with the end-result being positive-reassurance.
If you open "cmd" in the Microsoft Windows OS then you may be able to "ping -t -l 1500 localhost" what this is
supposed to be doing is enhancing the GUI (on display) If you need more a better explaination of what I am talking
about please contact me.
If created, this would be a automated GUI enhancement. The Windows Vista to 7 to 8 has the capability to enhance
the way the Windows OS GUI seems to look like. It can be done by pinging the computers' architectural mainframe.
In order to keep this project in-tact. Please send me a formidable message response.
You may remember me: I used to type sonikx as a nickname on the Eris-Free (Network) using mIRC. I have been
equipped with Windows thoroughly. There is a way it can be done.
