GUI... launch programs ?
I searched the forum, but I could only find info on Channels, Metadata agents... I was wondering if there is a way to execute programs/scripts from the interface, ideally from the "while playing" control interface ?
Here is why. Sometimes subtitles are out of sync more than the 10 seconds the subtitle correction slider allows me to adjust. So I have to dive into XML metadata to retrieve where Plex stored this subtitle file, launch a script I made to shift the timings, rename the file to the movie file name, place it in the same folder, and eventually refresh Plex... What a waste of time, away from the couch ;-)
Thanks for your tips.
m.
