Hamatv on unraid?
I am planning out my build and wanted to ask the community if anyone has used haman on unRaid already.
I saw from the readme that it worked on Linux and as unRaid is built on linux…it should work. But I was curious to see if anyone out here has already install Hama on unRaid and if there any gotcha you encountered or if its pretty straightforward.
Maybe post on this thread…
Yes it works fine as it should with Phaze’s Plex plugin on Unraid 6.3.2
For reference I have HAMA and ASS installed outside of the plex plugins folder with symlinks into the plugins folder.
This allows me to use git to pull regular fixes for these plugins with a minimum of effort.
