Hey, so I have been ripping a lot of my blu ray collection so I can put them on my Plex Server… I also had a hard drive get corrupted so I lost a chunk of my collection so I need to re rip and encode them… Since this happened I have decided I will also back up the encoded file so I can save time in the future if this happens again.
Since its been awhile since Ive done this I noticed the .265 codec is more supported now and having tested 1 movie with it, it seemed to play on all my TVs without any real issues. Switching to this codec will also aid me more in backing up the files, as I figured I have TONS of old DVD R blanks sitting around I’ll use those to back up the files… which sets my goal at adjusting handbrake so I can achieve decent quality on my movies while setting a goal on file size to under 4.7gb
Since I am an amateur at handbrake I figured I should run these setting by someone to make sure I am not doing something stupid that I will regret later.
I left picture and filters tabs alone
Video Tab:
Video Codec: H.265
FPS: 30 (Constant Framerate)
Optimize video: Medium Speed
Encoder Tune: None
Fast Decode Unchecked
Encoder Profile: Auto
Extra Options had this in it: strong-intra-smoothing=0:rect=0 I left that alone
Quality: Constant Quality: I currently have it at 20, will move up to 23 or so if file sizes get too large
Then Audio Tab:
I just Clear everything out and go Auto Passthru since I have no clue really what Im doing there so I try to play it safe
Subtitles:
I just throw the english subtitle in, if there are foreign parts I find that translation track then I burn that in
Chapters I leave alone
And finally the container I pick is .MKV
So does anyone see any obvious problems I will regret later? Id rather get it right now then waste the time it will take to encode these movies… I dont mind the slow encodes but I would rather not have to do the same movie many times
Thanks for the help
