Looking for some advice here. I running my Plex server on an old(ish) pc with an i3-4360 running Ubuntu server 19.10, which also serves as my in-home backup server. I am looking to expand my storage with a 5-bay drive enclosure, but I am weighing the pros and cons of using an enclosure with Hardware Raid vs a simple JBOD setup and running software RAID in Ubuntu.
By my understanding, Hardware raid is much faster, simpler, and less CPU-intensive, but I’m concerned about reliability in the budget-class enclosures that I can afford, and I understand that transferring the drives to a new enclosure will likely result in data loss even using the same brand/model of enclosure as a replacement.
On the other hand, software raid is slower and more intensive, but since I will only ever connect the enclosure to a single machine it seems like it should be more reliable so long as I keep my operating system properly backed up, as the RAID configuration will always be saved to the OS independent of which enclosure the drives are installed in.
I do stream 4K movies, and I routinely ask my poor, ageing CPU to transcode uncompressed Blu-Ray rips, so speed is important to me. At the same time, I rarely have more than 1-2 users at any given time.
Does anyone have experience with Hardware vs. Software RAID on a Plex server that might be able to point me in the right direction? My goal is 16TB of usable storage (after parity), with slightly better speed and reliability than a single 16TB drive, for under $1000.
