I’m testing hardware acceleration on a low-end Kaby Lake Celeron (G3930, which has QSV support) on Win10. I’ve run into a weird issue. Plex Server confirms that it’s hardware decoding/encoding a file:
Plex Web (Microsoft Edge)
Playing
Converting
Video Transcoding HEVC (hw) to H264 (hw)
Audio Transcoding DCA to AAC
But when I check the Task Manager, the CPU is floating between 90-100% usage, with most of that being the Plex Transcoder process. I can’t imagine the audio transcode process requires 100% CPU.
Is this normal? I’ve seen similar behavior on a quad-core Haswell i5 as well. If not, where should I look in the logs for more detail?
(This computer isn’t yet compatible with 1709, so there is no GPU section in the task manager to review)
Thank you!
Going to answer my own post after spending some time researching last night:
With Quick Sync enabled, the Plex server spikes to 90-100%… but only for the first 2-3 minutes. I haven’t researched why, but I’m guessing it’s immediately filling the buffer on the client, then doing real-time transcoding. Even on a low-end Kaby Lake Celeron, the CPU load is fairly minimal after the initial spike.
Also worth noting that I tested hardware encoding on a quad-core Haswell Core i5 system and a dual-core Kaby Lake Celeron last night. The Kaby Lake ran circles around the Core i5 with acceleration enabled. Not only was the video sharper, but seeking didn’t take 30-40 seconds with random failures. Very pleasant surprise, for a machine that cost less than $200 to assemble.
Mine is doing this as well. I can see that my nvidia 1070 gpu is going some sort of trans-coding as it has the plex transcoder process utilizing it. However, my intel 3770 cpu jumps from idle at around 15% to 100% when a transcode starts. I’ll give it more than 3 minutes to test if it goes down.
audo transcoding still does use the cpu, so even if you have HA for video, if you have a lower power cpu it still will have to keep up with high bit rate HD audio to > aac and/or eac3 or whatever.
And Hd audio conversion does use a bit more than say converting dts to ac3 or whatever lossy audio source.
Along with audio transcoding, transcoding 4k is a lot of IO, so your cpu/chipset/disk subsystem is going to be getting a large workout.
ie reading in a 4k stream, transcoding vid/aud on the fly, buffering, and sending it out to the client(s).
