May I have that full DEBUG ZIP file?
I can’t diagnose what’s happening from a snippet where it shows it’s loading the Nvidia driver modules as that only tells me ld-musl is correct,
Hey man, my previous message was typed wrong. I followed the instructions and it worked!
@jesplex I recognized the config and paths that you specified in your initial post: Hardware Transcoding stopped Working (GENTOO LINUX) - SOLVED - #33 by jesplex
I’m pretty sure you’re using my GitHub - mediadepot/docker-plex-cuda: linuxserver/docker-plex modified to add support for NVidia decoding + additional plugins. docker image, and I just wanted to give you an update. I’ve fixed this issue in the latest image, which is now available here:
I am actually using the linuxserver/plex image which your image is derived from. That’s probably why it’s familiar.
There is actually a version in the official portage tree, so you don’t need docker. It’s only the public releases though.
