Server Version#: Version 1.28.2.6151
Player Version#: Android 9.7.0.34811 and web Player
I have buyed a Quadro P2000 to give a chance to my CPU, I success to install it, the GPU is found by Plex :
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: video
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /srv/dev-disk-by-label-RAID/plex_temp/ (set in Preferences.xml)
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Processor: Intel(R) Core™ i7-4790 CPU @ 3.60GHz
PlexMediaServer install: Intel i915 Hardware: Not found
PlexMediaServer install: Nvidia GPU card: Found
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.28.2.6151-914ddd2b3 - Installation successful. Errors: 0, Warnings: 0
When I try to transcod with the option Hardware transcoding enabled the system never stat to transcode. and in the log i can see this error :
Does someone have any Idea ?
thank you by advance for your help
