Server Version#: 1.41.0.8992
Player Version#: N/A
Plex is running in linuxserver/plex:latest container:
Host OS:
PRETTY_NAME=“Ubuntu 24.04.1 LTS”
NAME=“Ubuntu”
VERSION_ID=“24.04”
VERSION=“24.04.1 LTS (Noble Numbat)”
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL=“https://www.ubuntu.com/”
SUPPORT_URL=“https://help.ubuntu.com/”
BUG_REPORT_URL=“https://bugs.launchpad.net/ubuntu/”
PRIVACY_POLICY_URL=“https://www.ubuntu.com/legal/terms-and-policies/privacy-policy”
CPU:
Architecture: aarch64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 64
On-line CPU(s) list: 0-63
Vendor ID: ARM
Model name: Neoverse-N1
Also when I
docker exec plex nvidia-smi … the GPU is avaliable in the container:
| NVIDIA-SMI 550.90.07 Driver Version: 550.90.07 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA RTX 2000 Ada Gene… Off | 00000004:01:00.0 Off | Off |
| 30% 57C P8 4W / 70W | 4MiB / 16380MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
I have Plex Pass(lifetime)
Given all the above, i expect the transcoding flag to be enabled, though when i visit to the transcoding tab through the webclient it isn’t available. Is there a remedy for this? Seems like there is a x64/amd64 check that prevents this. Is there a change in configurations i can make to enable this, or is this just a limitation of the system.
