Show package contents of your new app PMS and rename Applications/PMS.app/Contents/MacOS/Plex Media Server to PMS
Plex app would not launch, I had to rename it back
You dont have to rename /applications/plex media server.app to pms.app if you dont want to it works either way as long as you change the plist accordingly to whatever name u like same goes for renaming the other portion to pms as well
AND THE PLEX MEDIA SERVER PLIST IS BORN! Made by me
1. Copy your plex app and rename it to PMS in /applications 2. Show package contents of your new app PMS and rename Applications/PMS.app/Contents/MacOS/Plex Media Server to PMS 3. Copy the com.plex.pms.plist to /library/lauchdaemons 4. Fire up terminal and sudo su enter password. 5. Change directory to /library/launchdaemons 6. Enter this in terminal: chown root:wheel com.plex.pms.plist 7. Then this: sudo launchctl load /Library/LaunchDaemons/com.plex.pms.plist 8. I also added this to plexconnect.py above (import sys, time) at the beginning of the file I dont know if its needed but I wanted to be sure PMS was up and running prior to PLEX CONNECT Launchctl plist:
What do you explaining in this guide? there is the code for the applescript editor in page 9 that works perfect for me. Is there anything even better. so what does this guide do? can you please make him better?
I created this plist to automatically start PMS similar to checking the box open at login. The only difference is if PMS ever crashes the plist will automatically open PMS without having to goto the app and reopening it. Also if PMS is ever designed to boot prior to login this will be the plist you need.
This is why plex media center is not starting at boot prior to login on osx:
The Plex Media Server is an application that runs on your Macintosh or Windows PC. You can only access your Plex media while the server is running, so we recommend you allow the application to launch when you log-in. You must login to the user account for the server to load.
Great update. I installed the plist yesterday, it works great ! Just don't forget to install/launch also the PlexConnect plist (and also modify path in it) or PMS will not be accessible through ATV :D
Just a small question, I also get the "No Plex Media Server in proximity" message when I start Trailers on ATV. If I start again it then works. Is there a way to avoid it ?
I am having the same problem. I am not sure where to start. Anybody else resolve this issue in Mavericks yet?
I actually downgraded back to ML because i rely on PlexConnect on this system. From what i could tell, it's not specific to anything in the PlexConnect scripts. It is caused by launching the "screen" command with administrator privileges from the applescript. The exception is a guarded file descriptor, which i have no clue what that means and haven't found any useful information on the apple developer forums.
Maybe now that plexconnect has daemon support we won't need the applescript but i haven't had time to test that yet.
Yea, I was trying to mess around with the daemon and different plist but could not get it to work correctly yet. I don't think the code is where it needs to be yet. I have a few other python scripts auto starting with launch daemons and they all work fine but the plexconnect will not. Wanted to switch back to this in the mean time but I cannot get the app i created to work with Mavericks. I guess I will have to manually launch it until the daemon code works properly.
Ok i figured out how to fix this to work on Mavericks. By using the daemon script that has been added to the most recent version of PlexConnect, you can modify the applescript to use it instead of using the "screen" command. Here's the changes you need to make.
1. In PlexConnect_daemon.bash script, change the INSTALL_DIR variable to the fully path of your PlexConnect directory
INSTALL_DIR="/Users/rob/Development/PlexConnect"
2. In the applescript, change the "py" variable to point to the daemon script
set py to "/Users/rob/Development/PlexConnect/PlexConnect_daemon.bash"
3. In the applescript, change the "do shell" and "on quit" sections to pass the start and stop parameters to the daemon script. Take notice that there is a space before "start" and "stop"
do shell script py & " start" user name un password thePassword with administrator privileges
on quit
do shell script py & " stop" user name un password thePassword with administrator privileges
continue quit
end quit
Thanks for the help. I made the changes you suggested and everything worked perfect. I can at least use this AppleScript until we figure out the best way to use the daemon with launchd.
Thanks for the help. I made the changes you suggested and everything worked perfect. I can at least use this AppleScript until we figure out the best way to use the daemon with launchtl
I'm not 100% sure but I believe you can't have a user agent that needs root privileges since they run as the logged in user. It should be possible to run as a global daemon but since you need to be logged into a user account to run PMS, I don't see much benefit in launching as a global daemon.
I have actually been trying to launch it as a user. I have a headless Mac mini server that runs all my scripts. The plists are all in the /Users/Dan/Library/LaunchAgents and running at login but when trying to use the plists that people have posted on here and the plexconnect_daemon code I have not been able to get it to work. It will run but just crashes and trys to stay alive every 10 seconds. Probably should move this talk over to that forum though.
not the best solution but for now why not just add plexconnect.py to your login items. if you want to password protect and start pms use this app, it requires you to enable fast user login for the password portion, but it works for osx. once you figure out launchctl or automator switch to that in the future.
Why? We have an Applescript that can be saved as an application and launched as part of the login process. It's actually a pretty good solution. It looks and behaves just like any other application. If you just tried adding plexconnect.py to the login items, it wouldn't run as root and would fail.
Hi, didn't followed really last pages and want to catch up, so a few things:
i am using the script from post #97 i think, and PlexConnect app created with this script open on login and it's all good. Except of the fact that PMS will open without a password in the login screen with your guide, Will there be anything else different?
