Has anyone created an AppleScript/Application to launch PlexConnect at startup?
Hi, didn't followed really last pages and want to catch up, so a few things:
i am using the script from post #97 i think, and PlexConnect app created with this script open on login and it's all good. Except of the fact that PMS will open without a password in the login screen with your guide, Will there be anything else different?
Not sure i follow what you mean by "Except of the fact that PMS will open without a password in the login screen with your guide".  The applescript still requires an entry in Keychain so that it has access to the user and password to run the script with administrator privileges.  The only changes i made to the script were to not use the "screen" command since it appears broken in 10.9 Mavericks and instead rely on the daemon bash script that is now in the latest release of the PlexConnect code.
Of course he down, but his guide contains a .plist or something that make PMS open in the login screen, before putting the password in-To make the opening time of all login items shorter.
Just a sec, is there a new code for the applescript since post #97
What post is it? I want to update to be Mavericks-ready :)
The changes you need to make to the applescript to work with Mavericks is in post 233. You need to have the latest code for PlexConnect from Github to make it work since it relies on the daemon bash script.
Sorry, didn't catch it all up yet. What is the deamon bash script and what does it do?
Ok i figured out how to fix this to work on Mavericks. By using the daemon script that has been added to the most recent version of PlexConnect, you can modify the applescript to use it instead of using the "screen" command. Here's the changes you need to make.
1. In PlexConnect_daemon.bash script, change the INSTALL_DIR variable to the fully path of your PlexConnect directory
INSTALL_DIR="/Users/rob/Development/PlexConnect"
2. In the applescript, change the "py" variable to point to the daemon script
set py to "/Users/rob/Development/PlexConnect/PlexConnect_daemon.bash"
3. In the applescript, change the "do shell" and "on quit" sections to pass the start and stop parameters to the daemon script. Take notice that there is a space before "start" and "stop"
do shell script py & " start" user name un password thePassword with administrator privileges
on quit
do shell script py & " stop" user name un password thePassword with administrator privileges
continue quit
end quit
Will this work on ML too? I'm not on Mavericks yet. And the deamon file will change sometimes in the future, so i'll have to do this every time?
And about the last step with the do shell stuff-should i just Rewrite your do shell and on quit or add it? here's my do shell and on quit, what should i do with them?
do shell script "screen -A -m -d -S PlexConnect " & py user name un password thePassword with administrator privileges
on quit
do shell script "kill `ps -u root | grep [P]lexConnect | grep [Pp]ython | awk '{print $2}'`" user name un password thePassword with administrator privileges
continue quit
end quit
on quit
continue quit
end quit
Ok, answered a few of my own questions:
It works with ML.
I replaced the do shell and on quit with the new lines .. And it works
Last question:
The deamon file will change in the future, with more lines, fixes & stuff, so i'll have to edit it every time?
It works with ML.
Last question:
If the daemon file changes in the github repository, you'll need to just change the INSTALL_DIR variable in the daemon script. No changes would be required to the applescript.
Understood that :)
But why can't we develop an app in Xcode based on this applescript that'll check for updates and PlexConnect folder will be installed in it's files, so the install_dir will be the same at all devices? It'll be on the bar like PMS and download the newest zip automatically without telling you, and when the code itself will update, there will be a check for updates button.
They are working on a launcher it seems upstream. There is a comment that describes how to create the launcher:
http://forums.plexapp.com/index.php/topic/70149-has-anyone-created-an-applescriptapplication-to-launch-plexconnect-at-startup/page-5#entry424256
For the time being, I created an Application to make launching PlexConnect.py easier with automator. Here is location of the one I created with included icon. In directions below there is link to a tarball link if you do not want to clone the repo.
https://github.com/sbradley7777/dot.config/tree/master/osx/automator/automator.apps/Launch-PlexConnect.app
How to install and run:
1) You will need to create a keychain for PlexConnect.py to use that has admin rights so that sudo can be ran:
   login -> password -> application  called PlexConnect
2) Create a symlink for PlexConnect.py
$ mkdir ~/bin
$ ln -s ~/github/PlexConnect/PlexConnect.py ~/bin/PlexConnect.py
3) Clone the repo or download the tarball that contains Launch-PlexConnect.app.
     If you download the tarball then just extract the tarball if OSX does not do automatically.
$ cd ~/Downloads
$ tar jxvf Launch-PlexConnect.app.tar.bz2
4) To launch the app Launch-PlexConnect.app then just double click on the app or add to startup login.
Miscellaneous  Items
If you need to stop or list processes of the apps then just add the following alias to your ~/.bashrc file.
alias kill_plexconnect="sudo pkill -9 -f PlexConnect.py";
alias ps_plexconnect="pgrep -l -f PlexConnect.py";
The run the following command to source the new alias in. If PlexConnect.py it will list any running processes, kill any running processes, and then will list any running processes that contain the string PlexConnect.py.
$ source ~/.bashrc
$ ps_plexconnect
$ kill_plexconnect
$ ps_plexconnect
I agree that we need a better solution that does not involve sudo/root to open sockets. I am not sure if possible in OSX.
UPDATE:
I updated the automater app so that a generic path is used: ~/bin/PlexConnect.py. This means that there is no need to modify the automater application.
If you have questions or problems just reply to thread.
UPDATE:
I removed automator from my git repo master, but here is commit before I removed it: https://github.com/sbradley7777/dot.config/blob/73892d56b226d6eadbf0f21579d65bdfe7de02be/osx/automator/automator.apps/Launch-PlexConnect.app.tar.bz2
For now, I wanted to create a launcher and here is location of the one I created with included icon
You will need to create a keychain for PlexConnect to use that has admin rights so that sudo can be ran:
The run the following command if PlexConnect is running. If you want to source it in the current terminal or you will need to logout to run in terminal:
$ source ~/.bashrc
$ ps_plexconnect
$ kill_plexconnect
$ ps_plexconnect
UPDATE:
Just forgot that install path is different, so you will need to change that in workflow file. Might fix that later.
https://github.com/sbradley7777/dot.config/blob/master/osx/automator/automator.apps/Launch-PlexConnect.app/Contents/document.wflow#L58
But is there a problem to create a normal app based on the apple script with all the features i talked about?
Mavericks launchctl and applescript complete guide moved to here:
http://forums.plexapp.com/index.php/topic/84307-launchctl-and-applescript-methods-for-plexconnect-on-mavericks-osx/
I created a easy way to autostart plexconnect using applescript on mavericks if anyone is interested. Its based on the old plexconnect.py but works well for my situation. I have been told this may be a security issue on this forum so use at your own risk. Im sure you could change it to work with the newer versions of plexconnect and there is launchctl options as well but I prefer applescript so to each their own. Until a sure fire way is created with applescript if it ever is I personally will be using this instead of launchctl. Thanks to chrisbcole for his OP on this. Enjoy :)
Fastuser.app info is in my signature if needed. Here are the icons as well if needed.
That's actually just like applescript so don't need it :) And added icon long time ago.
What is needed is a real applications based on the apple script with all the features i already talked about ..
on quit
continue quit
end quit
I was stupid enough to update to Maverick, lots of things are not working anymore..  Seems there is no way back either.
One of the programs that dont work is PlexConnect, have very limited knowledge and even less experience in banging about in .py and such like...
I can't figure out what you mean by: 2. In the applescript, change the "py" variable to point to the daemon script
I have looked in all he files in the PlexConnect directory and can not figure out which file you mean, if I did i don't know here to change/paste what you are suggesting.
I made the change to PlexConnect_daemon.bash.
Please help!
That’s the change required to the AppleScript in post 97.
 Ok, I made the above changes and viola it works until I reboot. Currently, I have my plex media server and the PlexConnect Apple Script to "Open on Login"
Prior to Maveriks, I just turn on the computer, both would load, and trailer would work perfectly.
Now when I reboot, both load as per previously, however going to trailers on ATV gives me an error..."no plex Library Sections Available".
All I have to do is stop the Plex Script and restart it and I can get trailers to work.
I know this is not a big deal but I have little kids that have figured out the ATV button pushes to get their shows on trailers but the computer (stopping and restarting the Plex Script" is a little beyond them yet.
I believe it likely relates to the boot login order but I cannot get it figured out.
Here is the ;log after I reboot, shut down Plex script and restart pled script.
10/26/2013 4:32:00.922 PM shutdown[421]: SHUTDOWN_TIME: 1382826720 921807
10/26/2013 4:32:00.944 PM Plex Media Server[244]: XPC error messaging com.apple.IconServicesAgent: Connection interrupted
10/26/2013 4:32:00.944 PM Plex Media Server[244]: XPC error messaging com.apple.IconServicesAgent: Connection invalid
10/26/2013 4:32:00.947 PM Dock[176]: XPC error messaging com.apple.IconServicesAgent: Connection interrupted
10/26/2013 4:32:00.949 PM Dock[176]: XPC error messaging com.apple.IconServicesAgent: Connection invalid
10/26/2013 4:32:00.950 PM quicklookd[198]: XPC error messaging com.apple.IconServicesAgent: Connection interrupted
10/26/2013 4:32:13.000 PM bootlog[0]: BOOT_TIME 1382826733 0
10/26/2013 4:32:16.000 PM syslogd[19]: Configuration Notice:
ASL Module "com.apple.appstore" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
ASL Module "com.apple.authd" claims selected messages.
ASL Module "com.apple.bookstore" claims selected messages.
ASL Module "com.apple.eventmonitor" claims selected messages.
ASL Module "com.apple.install" claims selected messages.
ASL Module "com.apple.iokit.power" claims selected messages.
ASL Module "com.apple.mail" claims selected messages.
ASL Module "com.apple.MessageTracer" claims selected messages.
ASL Module "com.apple.performance" claims selected messages.
ASL Module "com.apple.securityd" claims selected messages.
10/26/2013 4:32:16.000 PM kernel[0]: Longterm timer threshold: 1000 ms
10/26/2013 4:32:16.000 PM kernel[0]: PMAP: PCID enabled
10/26/2013 4:32:16.000 PM kernel[0]: Darwin Kernel Version 13.0.0: Thu Sep 19 22:22:27 PDT 2013; root:xnu-2422.1.72~6/RELEASE_X86_64
10/26/2013 4:32:16.000 PM kernel[0]: vm_page_bootstrap: 1974004 free pages and 106764 wired pages
10/26/2013 4:32:16.000 PM kernel[0]: kext submap [0xffffff7f807a5000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff80007a5000]
10/26/2013 4:32:16.000 PM kernel[0]: zone leak detection enabled
10/26/2013 4:32:16.000 PM kernel[0]: "vm_compressor_mode" is 4
10/26/2013 4:32:16.000 PM kernel[0]: standard timeslicing quantum is 10000 us
10/26/2013 4:32:16.000 PM kernel[0]: standard background quantum is 2500 us
10/26/2013 4:32:16.000 PM kernel[0]: mig_table_max_displ = 74
10/26/2013 4:32:16.000 PM kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=0 Enabled
10/26/2013 4:32:16.000 PM kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=1 Enabled
10/26/2013 4:32:16.000 PM kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=4 Enabled
10/26/2013 4:32:16.000 PM kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=5 Enabled
10/26/2013 4:32:16.000 PM kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=0 Disabled
10/26/2013 4:32:16.000 PM kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=0 Disabled
10/26/2013 4:32:16.000 PM kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=0 Disabled
10/26/2013 4:32:16.000 PM kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=0 Disabled
10/26/2013 4:32:16.000 PM kernel[0]: calling mpo_policy_init for TMSafetyNet
10/26/2013 4:32:16.000 PM kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
10/26/2013 4:32:16.000 PM kernel[0]: calling mpo_policy_init for Sandbox
10/26/2013 4:32:16.000 PM kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
10/26/2013 4:32:16.000 PM kernel[0]: calling mpo_policy_init for Quarantine
10/26/2013 4:32:16.000 PM kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
10/26/2013 4:32:16.000 PM kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
10/26/2013 4:32:16.000 PM kernel[0]: The Regents of the University of California. All rights reserved.
10/26/2013 4:32:16.000 PM kernel[0]: MAC Framework successfully initialized
10/26/2013 4:32:16.000 PM kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
10/26/2013 4:32:16.000 PM kernel[0]: AppleKeyStore starting (BUILT: Sep 19 2013 22:20:34)
10/26/2013 4:32:16.000 PM kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
10/26/2013 4:32:16.000 PM kernel[0]: ACPI: sleep states S3 S4 S5
10/26/2013 4:32:16.000 PM kernel[0]: pci (build 22:16:29 Sep 19 2013), flags 0x63008, pfm64 (36 cpu) 0xf80000000, 0x80000000
10/26/2013 4:32:16.000 PM kernel[0]: [ PCI configuration begin ]
10/26/2013 4:32:16.000 PM kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 0035
10/26/2013 4:32:16.000 PM kernel[0]: AppleIntelCPUPowerManagement: (built 22:16:38 Sep 19 2013) initialization complete
10/26/2013 4:32:16.000 PM kernel[0]: console relocated to 0xf80030000
10/26/2013 4:32:16.000 PM kernel[0]: [ PCI configuration end, bridges 7, devices 16 ]
10/26/2013 4:32:16.000 PM kernel[0]: [ PCI configuration end, bridges 8, devices 22 ]
10/26/2013 4:32:16.000 PM kernel[0]: mcache: 4 CPU(s), 64 bytes CPU cache line size
10/26/2013 4:32:16.000 PM kernel[0]: mbinit: done [96 MB total pool size, (64/32) split]
10/26/2013 4:32:16.000 PM kernel[0]: Pthread support ABORTS when sync kernel primitives misused
10/26/2013 4:32:16.000 PM kernel[0]: rooting via boot-uuid from /chosen: 7089BCE5-ABF8-32A8-BEAF-18271FF32E20
10/26/2013 4:32:16.000 PM kernel[0]: Waiting on IOProviderClassIOResourcesIOResourceMatchboot-uuid-media
10/26/2013 4:32:16.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
10/26/2013 4:32:16.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
10/26/2013 4:32:16.000 PM kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
10/26/2013 4:32:16.000 PM kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
10/26/2013 4:32:16.000 PM kernel[0]: AppleIntelCPUPowerManagementClient: ready
10/26/2013 4:32:16.000 PM kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/APPLE SSD TS512B Media/IOGUIDPartitionScheme/Customer@2
10/26/2013 4:32:16.000 PM kernel[0]: BSD root: disk0s2, major 1, minor 2
10/26/2013 4:32:16.000 PM kernel[0]: BTCOEXIST off
10/26/2013 4:32:16.000 PM kernel[0]: BRCM tunables:
10/26/2013 4:32:16.000 PM kernel[0]: pullmode[1] txringsize[  256] txsendqsize[1024] reapmin[   32] reapcount[  128]
10/26/2013 4:32:16.000 PM kernel[0]: FireWire (OHCI) Lucent ID 5901 built-in now active, GUID e80688fffec1dc54; max speed s800.
10/26/2013 4:32:16.000 PM kernel[0]: USBMSC Identifier (non-unique): 000000009833 0x5ac 0x8403 0x9833, 2
10/26/2013 4:32:16.000 PM kernel[0]: hfs: mounted Macintosh HD on device root_device
10/26/2013 4:32:13.692 PM com.apple.launchd[1]: *** launchd[1] has started up. ***
10/26/2013 4:32:13.692 PM com.apple.launchd[1]: *** Shutdown logging is enabled. ***
10/26/2013 4:32:16.215 PM com.apple.launchd[1]: (com.insynchq.insync.daemon) Unknown key for string: Version
10/26/2013 4:32:16.215 PM com.apple.launchd[1]: (com.insynchq.insync.daemon) Unknown key: Version
10/26/2013 4:32:16.281 PM com.apple.SecurityServer[15]: Session 100000 created
10/26/2013 4:32:16.000 PM kernel[0]: IO80211Controller::dataLinkLayerAttachComplete():  adding AppleEFINVRAM notification
10/26/2013 4:32:16.000 PM kernel[0]: IO80211Interface::efiNVRAMPublished():
10/26/2013 4:32:17.522 PM com.apple.SecurityServer[15]: Entering service
10/26/2013 4:32:17.591 PM UserEventAgent[11]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
10/26/2013 4:32:17.608 PM UserEventAgent[11]: Captive: CNPluginHandler en1: Inactive
10/26/2013 4:32:17.000 PM kernel[0]: AGC: 3.4.12, HW version=1.9.21, flags:0, features:20600
10/26/2013 4:32:17.000 PM kernel[0]: fNumVRAMBlocks is 4
10/26/2013 4:32:17.000 PM kernel[0]: Previous Shutdown Cause: 3
10/26/2013 4:32:17.000 PM kernel[0]: SMC::smcInitHelper ERROR: MMIO regMap == NULL - fall back to old SMC mode
10/26/2013 4:32:17.000 PM kernel[0]: IOBluetoothUSBDFU::probe
10/26/2013 4:32:17.000 PM kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8218 FirmwareVersion - 0x0042
10/26/2013 4:32:17.000 PM kernel[0]: **** [IOBluetoothHostControllerUSBTransport][start] -- completed -- result = TRUE -- 0x3c00 ****
10/26/2013 4:32:17.000 PM kernel[0]: **** [BroadcomBluetoothHostControllerUSBTransport][start] -- Completed -- 0x3c00 ****
10/26/2013 4:32:17.000 PM kernel[0]: NVDAStartup: Official
10/26/2013 4:32:17.000 PM kernel[0]: NVDANV50HAL loaded and registered
10/26/2013 4:32:17.000 PM kernel[0]: init
10/26/2013 4:32:17.000 PM kernel[0]: probe
10/26/2013 4:32:17.000 PM kernel[0]: APExtframeBuffer starting: max resolution 1920x1080
10/26/2013 4:32:17.000 PM kernel[0]: Initializing Framebuffer.
10/26/2013 4:32:17.000 PM kernel[0]: start
10/26/2013 4:32:17.000 PM kernel[0]: [IOBluetoothHCIController][staticBluetoothHCIControllerTransportShowsUp] -- Received Bluetooth Controller register service notification -- 0x3c00
10/26/2013 4:32:17.000 PM kernel[0]: [IOBluetoothHCIController][start] -- completed
10/26/2013 4:32:17.000 PM kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
10/26/2013 4:32:17.000 PM kernel[0]: **** [IOBluetoothHCIController][protectedBluetoothHCIControllerTransportShowsUp] -- Connected to the transport successfully -- 0x0bc0 -- 0x6800 -- 0x3c00 ****
10/26/2013 4:32:17.000 PM kernel[0]: flow_divert_kctl_disconnect (0): disconnecting group 1
10/26/2013 4:32:18.000 PM kernel[0]: IOMemoryDescriptor 0x62d1abb5ee4bb789 prepared read only
10/26/2013 4:32:18.000 PM kernel[0]: Backtrace 0xffffff80006b982e 0xffffff7f821c20e1 0xffffff7f821ccfe2 0xffffff800069297f 0xffffff800069253f 0xffffff800068e119 0xffffff8000693093
10/26/2013 4:32:18.000 PM kernel[0]: Kernel Extensions in backtrace:
10/26/2013 4:32:18.000 PM kernel[0]: com.apple.driver.AppleIntelHDGraphics(8.1.8)[CA277D41-793F-3665-8F67-04A8B906142B]@0xffffff7f8afa4000->0xffffff7f8b063fff
10/26/2013 4:32:18.000 PM kernel[0]: dependency: com.apple.iokit.IOPCIFamily(2.8)[447B4896-16FF-3616-95A2-1C516B2A1498]@0xffffff7f896c4000
10/26/2013 4:32:18.000 PM kernel[0]: dependency: com.apple.iokit.IOGraphicsFamily(2.3.6)[38E388A5-92D6-3388-B799-F2498E582287]@0xffffff7f899e1000
10/26/2013 4:32:18.000 PM kernel[0]: IOMemoryDescriptor 0x62d1abb5ee53be89 prepared read only
10/26/2013 4:32:18.000 PM kernel[0]: Backtrace 0xffffff80006b982e 0xffffff7f821c22db 0xffffff7f821ccfe2 0xffffff800069297f 0xffffff800069253f 0xffffff800068e119 0xffffff8000693093
10/26/2013 4:32:18.000 PM kernel[0]: **** [IOBluetoothHostControllerUSBTransport][SuspendDevice] -- Suspend -- suspendDeviceCallResult = 0x0000 (kIOReturnSuccess) -- 0x3c00 ****
10/26/2013 4:32:18.000 PM kernel[0]: DSMOS has arrived
10/26/2013 4:32:18.000 PM kernel[0]: SMC::smcReadKeyAction ERROR: smcReadData8 failed for key MOTP (kSMCKeyNotFound)
10/26/2013 4:32:18.000 PM kernel[0]: [AGPM Controller] build GPUDict by Vendor8086Device0046
10/26/2013 4:32:18.000 PM kernel[0]: [AGPM Controller] build GPUDict by Vendor10deDevice0a29
10/26/2013 4:32:18.725 PM com.apple.launchd[1]: (com.displaylink.usbnivolistener[86]) Job specified non-existent working directory: /System/Library/Extensions/DisplayLinkDriver.kext/DisplayLinkAgent
10/26/2013 4:32:18.745 PM com.apple.launchd[1]: (com.displaylink.usbnivolistener[86]) Job failed to exec(3). Setting up event to tell us when to try again: 2: No such file or directory
10/26/2013 4:32:18.745 PM com.apple.launchd[1]: (com.displaylink.usbnivolistener[86]) Job failed to exec(3) for weird reason: 2
10/26/2013 4:32:18.753 PM loginwindow[65]: Login Window Application Started
10/26/2013 4:32:18.756 PM hidd[70]: void __IOHIDPlugInLoadBundles(): Loaded 0 HID plugins
10/26/2013 4:32:18.757 PM hidd[70]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
10/26/2013 4:32:18.758 PM awacsd[79]: Starting awacsd connectivity_executables-97 (Aug 24 2013 23:49:23)
10/26/2013 4:32:19.000 PM kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
10/26/2013 4:32:19.791 PM configd[18]: network changed.
10/26/2013 4:32:19.791 PM configd[18]: setting hostname to "Deans-MacBook-Pro.local"
10/26/2013 4:32:20.000 PM kernel[0]: VM Swap Subsystem is ON
10/26/2013 4:32:20.368 PM awacsd[79]: InnerStore CopyAllZones: no info in Dynamic Store
10/26/2013 4:32:20.470 PM sudo[89]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/mknod /dev/bpf4 c 23 4
10/26/2013 4:32:20.477 PM digest-service[87]: label: default
10/26/2013 4:32:20.477 PM digest-service[87]: dbname: od:/Local/Default
10/26/2013 4:32:20.477 PM digest-service[87]: mkey_file: /var/db/krb5kdc/m-key
10/26/2013 4:32:20.477 PM digest-service[87]: acl_file: /var/db/krb5kdc/kadmind.acl
10/26/2013 4:32:20.480 PM digest-service[87]: digest-request: uid=0
10/26/2013 4:32:20.485 PM mDNSResponder[62]: mDNSResponder mDNSResponder-522.1.11 (Aug 24 2013 23:49:34) starting OSXVers 13
10/26/2013 4:32:20.491 PM sudo[98]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/mknod /dev/bpf5 c 23 5
10/26/2013 4:32:20.508 PM sudo[100]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/mknod /dev/bpf6 c 23 6
10/26/2013 4:32:20.532 PM sudo[106]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod a=rwx /dev/bpf0 /dev/bpf1 /dev/bpf2 /dev/bpf3 /dev/bpf4 /dev/bpf5 /dev/bpf6
10/26/2013 4:32:20.532 PM digest-service[87]: digest-request: netr probe 0
10/26/2013 4:32:20.533 PM digest-service[87]: digest-request: init request
10/26/2013 4:32:20.543 PM digest-service[87]: digest-request: init return domain: BUILTIN server: DEANS-MACBOOK-PRO indomain was:
10/26/2013 4:32:20.544 PM apsd[81]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
10/26/2013 4:32:20.549 PM sudo[108]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod a=rwx /dev/bpf0 /dev/bpf1 /dev/bpf2 /dev/bpf3 /dev/bpf4 /dev/bpf5 /dev/bpf6
10/26/2013 4:32:20.552 PM com.apple.usbmuxd[46]: usbmuxd-323 on Jul 29 2013 at 23:21:29, running 64 bit
10/26/2013 4:32:20.591 PM configd[18]: network changed.
10/26/2013 4:32:20.593 PM configd[18]: network changed: DNS*
10/26/2013 4:32:20.599 PM mDNSResponder[62]: D2D_IPC: Loaded
10/26/2013 4:32:20.599 PM mDNSResponder[62]: D2DInitialize succeeded
10/26/2013 4:32:20.603 PM mDNSResponder[62]:   4: Listening for incoming Unix Domain Socket client requests
10/26/2013 4:32:20.651 PM networkd[124]: networkd.124 built Aug 24 2013 22:08:46
10/26/2013 4:32:20.655 PM WindowServer[95]: Server is starting up
10/26/2013 4:32:20.661 PM WindowServer[95]: Session 256 retained (2 references)
10/26/2013 4:32:20.661 PM WindowServer[95]: Session 256 released (1 references)
10/26/2013 4:32:20.670 PM mds[61]: (Normal) FMW: FMW 0 0
10/26/2013 4:32:20.686 PM WindowServer[95]: Session 256 retained (2 references)
10/26/2013 4:32:20.689 PM WindowServer[95]: init_page_flip: page flip mode is on
10/26/2013 4:32:20.829 PM airportd[83]: airportdProcessDLILEvent: en1 attached (up)
10/26/2013 4:32:20.000 PM kernel[0]: createVirtIf(): ifRole = 1
10/26/2013 4:32:20.000 PM kernel[0]: in func createVirtualInterface ifRole = 1
10/26/2013 4:32:20.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init name role 1
10/26/2013 4:32:20.000 PM kernel[0]: AirPort_Brcm4331_P2PInterface::init() role 1
10/26/2013 4:32:20.000 PM kernel[0]: Created virtif 0xffffff801cf33000 p2p0
10/26/2013 4:32:20.918 PM systemkeychain[93]: done file: /var/run/systemkeychaincheck.done
10/26/2013 4:32:20.926 PM mds[61]: (Warning) Server: No stores registered for metascope "kMDQueryScopeComputer"
10/26/2013 4:32:20.952 PM sudo[133]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/mknod /dev/bpf4 c 23 4
10/26/2013 4:32:20.965 PM sudo[137]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/mknod /dev/bpf5 c 23 5
10/26/2013 4:32:20.981 PM sudo[139]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/mknod /dev/bpf6 c 23 6
10/26/2013 4:32:21.004 PM locationd[67]: NBB-Could not get UDID for stable refill timing, falling back on random
10/26/2013 4:32:21.005 PM com.apple.kextd[12]: kext foo.tun  100009000 is in exception list, allowing to load
10/26/2013 4:32:21.000 PM kernel[0]: tun kernel extension version 20111101
10/26/2013 4:32:21.181 PM locationd[67]: Location icon should now be in state 'Inactive'
10/26/2013 4:32:21.312 PM sandboxd[127]: ([83]) airportd(83) deny file-read-data /private/var/root/Library/Preferences/ByHost/.GlobalPreferences.C87E9CC0-0D9F-5A12-BF86-040E63AF8B7F.plist
10/26/2013 4:32:21.000 PM kernel[0]: AppleLMUController found an AG vendor product (0x9cb7), notifying SMC.
10/26/2013 4:32:21.000 PM kernel[0]: APExternalDisplay Memory Reserved: 8331264 bytes
10/26/2013 4:32:21.980 PM WindowServer[95]: Found 1 modes for display 0x00000000 [1, 0]
10/26/2013 4:32:22.000 PM kernel[0]: en1: 802.11d country code set to 'US'.
10/26/2013 4:32:22.000 PM kernel[0]: en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
10/26/2013 4:32:22.043 PM WindowServer[95]: Found 42 modes for display 0x00000000 [33, 9]
10/26/2013 4:32:22.047 PM WindowServer[95]: Found 1 modes for display 0x00000000 [1, 0]
10/26/2013 4:32:22.048 PM WindowServer[95]: Found 1 modes for display 0x00000000 [1, 0]
10/26/2013 4:32:22.106 PM WindowServer[95]: mux_initialize: Mode is dynamic
10/26/2013 4:32:22.108 PM WindowServer[95]: Found 42 modes for display 0x00000000 [33, 9]
10/26/2013 4:32:22.115 PM WindowServer[95]: Found 1 modes for display 0x00000000 [1, 0]
10/26/2013 4:32:22.176 PM WindowServer[95]: WSMachineUsesNewStyleMirroring: false
10/26/2013 4:32:22.178 PM WindowServer[95]: Display 0x04272dc0: GL mask 0x5; bounds (0, 0)[1680 x 1050], 42 modes available
Main, Active, on-line, enabled, built-in, boot, Vendor 610, Model 9cb7, S/N 0, Unit 0, Rotation 0
UUID 0x0dd0e4cb9815451eb82218b6243ae528
10/26/2013 4:32:22.178 PM WindowServer[95]: Display 0x003f003f: GL mask 0x8; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 3, Rotation 0
UUID 0xffffffffffffffffffffffffffffffff
10/26/2013 4:32:22.178 PM WindowServer[95]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
10/26/2013 4:32:22.179 PM WindowServer[95]: WSSetWindowTransform: Singular matrix
10/26/2013 4:32:22.180 PM WindowServer[95]: WSSetWindowTransform: Singular matrix
10/26/2013 4:32:22.185 PM WindowServer[95]: Display 0x04272dc0: GL mask 0x5; bounds (0, 0)[1680 x 1050], 42 modes available
10/26/2013 4:32:22.185 PM WindowServer[95]: Display 0x003f003f: GL mask 0x8; bounds (2704, 0)[1 x 1], 1 modes available
10/26/2013 4:32:22.185 PM WindowServer[95]: Display 0x003f003d: GL mask 0x2; bounds (2705, 0)[1 x 1], 1 modes available
10/26/2013 4:32:22.185 PM WindowServer[95]: CGXPerformInitialDisplayConfiguration
10/26/2013 4:32:22.185 PM WindowServer[95]:   Display 0x04272dc0: Unit 0; Alias(0, 0x5); Vendor 0x610 Model 0x9cb7 S/N 0 Dimensions 13.03 x 8.15; online enabled built-in, Bounds (0,0)[1680 x 1050], Rotation 0, Resolution 1
10/26/2013 4:32:22.186 PM WindowServer[95]:   Display 0x003f003f: Unit 3; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2704,0)[1 x 1], Rotation 0, Resolution 1
10/26/2013 4:32:22.186 PM WindowServer[95]:   Display 0x003f003d: Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2705,0)[1 x 1], Rotation 0, Resolution 1
10/26/2013 4:32:22.186 PM WindowServer[95]: CGXMuxBoot: Boot normal
10/26/2013 4:32:22.246 PM WindowServer[95]: GLCompositor: GL renderer id 0x01022612, GL mask 0x00000003, accelerator 0x00004ba3, unit 0, caps QEX|MIPMAP, vram 512 MB
10/26/2013 4:32:22.260 PM WindowServer[95]: GLCompositor: GL renderer id 0x01022612, GL mask 0x00000003, texture max 8192, viewport max {8192, 8192}, extensions FPRG|NPOT|GLSL|FLOAT
10/26/2013 4:32:22.260 PM WindowServer[95]: GLCompositor: GL renderer id 0x01024300, GL mask 0x00000004, accelerator 0x00003427, unit 2, caps QEX|MIPMAP, vram 288 MB
10/26/2013 4:32:22.263 PM WindowServer[95]: GLCompositor: GL renderer id 0x01024300, GL mask 0x00000004, texture max 8192, viewport max {8192, 8192}, extensions FPRG|NPOT|GLSL|FLOAT
10/26/2013 4:32:22.263 PM WindowServer[95]: GLCompositor enabled for tile size [256 x 256]
10/26/2013 4:32:22.263 PM WindowServer[95]: CGXGLInitMipMap: mip map mode is on
10/26/2013 4:32:22.000 PM kernel[0]: MacAuthEvent en1   Auth result for: 84:1b:5e:45:f5:32  MAC AUTH succeeded
10/26/2013 4:32:22.000 PM kernel[0]: wlEvent: en1 en1 Link UP virtIf = 0
10/26/2013 4:32:22.000 PM kernel[0]: AirPort: Link Up on en1
10/26/2013 4:32:22.000 PM kernel[0]: en1: BSSID changed to 84:1b:5e:45:f5:32
10/26/2013 4:32:22.288 PM loginwindow[65]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
10/26/2013 4:32:22.000 PM kernel[0]: AirPort: RSN handshake complete on en1
10/26/2013 4:32:22.367 PM WindowServer[95]: Display 0x04272dc0: Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 12)
10/26/2013 4:32:22.408 PM com.apple.launchd[1]: (com.displaylink.useragent[159]) Job specified non-existent working directory: /System/Library/Extensions/DisplayLinkDriver.kext/DisplayLinkAgent
10/26/2013 4:32:22.414 PM com.apple.launchd[1]: (com.displaylink.useragent[159]) Job failed to exec(3). Setting up event to tell us when to try again: 2: No such file or directory
10/26/2013 4:32:22.414 PM com.apple.launchd[1]: (com.displaylink.useragent[159]) Job failed to exec(3) for weird reason: 2
10/26/2013 4:32:22.415 PM launchctl[151]: com.apple.findmymacmessenger: Already loaded
10/26/2013 4:32:22.445 PM com.apple.SecurityServer[15]: Session 100005 created
10/26/2013 4:32:22.510 PM loginwindow[65]: Setting the initial value of the magsave brightness level 1
10/26/2013 4:32:22.517 PM UserEventAgent[153]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
10/26/2013 4:32:22.558 PM loginwindow[65]: Login Window Started Security Agent
10/26/2013 4:32:22.000 PM kernel[0]: flow_divert_kctl_disconnect (0): disconnecting group 1
10/26/2013 4:32:22.650 PM SecurityAgent[161]: This is the first run
10/26/2013 4:32:22.650 PM SecurityAgent[161]: MacBuddy was run = 0
10/26/2013 4:32:22.667 PM WindowServer[95]: _CGXGLDisplayContextForDisplayDevice: acquired display context (0x7fd193c0c080) - enabling OpenGL
10/26/2013 4:32:22.670 PM SecurityAgent[161]: User info context values set for Deurich
10/26/2013 4:32:23.008 PM loginwindow[65]: Login Window - Returned from Security Agent
10/26/2013 4:32:23.107 PM airportd[83]: _doAutoJoin: Already associated to “Gandalf_EXT”. Bailing on auto-join.
10/26/2013 4:32:23.143 PM loginwindow[65]: USER_PROCESS: 65 console
10/26/2013 4:32:23.000 PM kernel[0]: AppleKeyStore:Sending lock change 0
10/26/2013 4:32:23.280 PM com.apple.launchd.peruser.501[169]: Background: Aqua: Registering new GUI session.
10/26/2013 4:32:23.302 PM com.apple.launchd.peruser.501[169]: (com.apple.cmfsyncagent) Ignored this key: UserName
10/26/2013 4:32:23.302 PM com.apple.launchd.peruser.501[169]: (com.apple.EscrowSecurityAlert) Unknown key: seatbelt-profiles
10/26/2013 4:32:23.303 PM com.apple.launchd.peruser.501[169]: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10/26/2013 4:32:23.307 PM launchctl[171]: com.apple.pluginkit.pkd: Already loaded
10/26/2013 4:32:23.307 PM launchctl[171]: com.apple.sbd: Already loaded
10/26/2013 4:32:23.321 PM distnoted[173]: # distnote server agent  absolute time: 10.670207556   civil time: Sat Oct 26 16:32:23 2013   pid: 173 uid: 501  root: no
10/26/2013 4:32:23.579 PM WindowServer[95]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
10/26/2013 4:32:23.748 PM sharingd[190]: Starting Up...
10/26/2013 4:32:23.821 PM SystemUIServer[180]: Cannot find executable for CFBundle 0x7f9308c30100 (not loaded)
10/26/2013 4:32:23.976 PM SystemUIServer[180]: Cannot find executable for CFBundle 0x7f9308c3f240 (not loaded)
10/26/2013 4:32:24.002 PM SystemUIServer[180]: Cannot find executable for CFBundle 0x7f9308e409d0 (not loaded)
10/26/2013 4:32:24.159 PM com.apple.launchd.peruser.501[169]: (com.logmein.LMILaunchAgentFixer[218]) Exited with code: 2
10/26/2013 4:32:24.161 PM com.apple.launchd.peruser.501[169]: (com.displaylink.useragent[221]) Job specified non-existent working directory: /System/Library/Extensions/DisplayLinkDriver.kext/DisplayLinkAgent
10/26/2013 4:32:24.000 PM kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=223[GoogleSoftwareUp] final status 0x0, allow (remove VALID)ing page
10/26/2013 4:32:24.180 PM WindowServer[95]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
10/26/2013 4:32:24.180 PM com.apple.launchd.peruser.501[169]: (com.displaylink.useragent[221]) Exited with code: 2
10/26/2013 4:32:24.180 PM com.apple.launchd.peruser.501[169]: (com.displaylink.useragent) Throttling respawn: Will start in 5 seconds
10/26/2013 4:32:24.251 PM WindowServer[95]: Received display connect changed for display 0x4272dc0
10/26/2013 4:32:24.261 PM WindowServer[95]: Found 14 modes for display 0x04272dc0 [11, 3]
10/26/2013 4:32:24.284 PM WindowServer[95]: CGXMuxAcknowledge: Posting glitchless acknowledge
10/26/2013 4:32:24.380 PM com.apple.launchd.peruser.501[169]: (com.apple.CSConfigDotMacCert-deurich@me.com-SharedServices[224]) Exited with code: 2
10/26/2013 4:32:24.388 PM WindowServer[95]: Received display connect changed for display 0x4272dc0
10/26/2013 4:32:24.388 PM WindowServer[95]: Found 1 modes for display 0x04272dc0 [1, 0]
10/26/2013 4:32:24.389 PM WindowServer[95]: Received display connect changed for display 0x3f003d
10/26/2013 4:32:24.390 PM WindowServer[95]: Found 1 modes for display 0x003f003d [1, 0]
10/26/2013 4:32:24.394 PM apsd[81]: Unexpected connection from logged out uid 501
10/26/2013 4:32:24.405 PM com.apple.SecurityServer[15]: Session 100006 created
10/26/2013 4:32:24.532 PM 1PasswordAgent[222]: Starting 1PasswordAgent 3.8.21 #32009 built Apr 24 2013 16:09:31
10/26/2013 4:32:24.533 PM 1PasswordAgent[222]: Trying to load Localizable.strings [English] from the main bundle
10/26/2013 4:32:24.536 PM 1PasswordAgent[222]: Cannot find English version, using English localization for Localizable.strings
10/26/2013 4:32:24.579 PM accountsd[238]: assertion failed: 13A603: liblaunch.dylib + 25164 [FCBF0A02-0B06-3F97-9248-5062A9DEB32C]: 0x25
10/26/2013 4:32:24.910 PM configd[18]: network changed: DNS* Proxy
10/26/2013 4:32:24.910 PM UserEventAgent[11]: Captive: [CNInfoNetworkActive:1655] en1: SSID 'Gandalf_EXT' making interface primary (protected network)
10/26/2013 4:32:24.912 PM UserEventAgent[11]: Captive: CNPluginHandler en1: Evaluating
10/26/2013 4:32:24.913 PM UserEventAgent[11]: Captive: en1: Probing 'Gandalf_EXT'
10/26/2013 4:32:24.921 PM configd[18]: network changed: v4(en1!:192.168.1.70) DNS+ Proxy+ SMB
10/26/2013 4:32:24.997 PM UserEventAgent[11]: Captive: CNPluginHandler en1: Authenticated
10/26/2013 4:32:26.176 PM ntpd[43]: proto: precision = 1.000 usec
10/26/2013 4:32:26.606 PM Alfred 2[229]: [TIMER] 0.253273 seconds to initialise Alfred
10/26/2013 4:32:26.886 PM WindowServer[95]: Display 0x04272dc0: Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 12)
10/26/2013 4:32:26.947 PM Google Drive[237]: PyObjCPointer created: at 0xa11b2418 of type {__CFBoolean=}
10/26/2013 4:32:26.948 PM Google Drive[237]: PyObjCPointer created: at 0xa11b2410 of type {__CFBoolean=}
10/26/2013 4:32:26.950 PM Google Drive[237]: PyObjCPointer created: at 0xa11b2420 of type {__CFNumber=}
10/26/2013 4:32:26.952 PM Google Drive[237]: PyObjCPointer created: at 0xa11b2430 of type {__CFNumber=}
10/26/2013 4:32:26.952 PM Google Drive[237]: PyObjCPointer created: at 0xa11b2440 of type {__CFNumber=}
10/26/2013 4:32:27.213 PM Plex Media Server[232]: Unknown class 'NATMappingController', using 'NSObject' instead. Encountered in Interface Builder file at path /Applications/Plex Media Server.app/Contents/Resources/English.lproj/PMSStatusItem.nib.
10/26/2013 4:32:27.274 PM WindowServer[95]: Display 0x04272dc0: Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 12)
10/26/2013 4:32:27.345 PM xpcproxy[261]: assertion failed: 13A603: xpcproxy + 3438 [EE7817B0-1FA1-3603-B88A-BD5E595DA86F]: 0x2
10/26/2013 4:32:27.427 PM com.apple.IconServicesAgent[258]: IconServicesAgent launched.
10/26/2013 4:32:27.439 PM com.apple.SecurityServer[15]: Session 100008 created
10/26/2013 4:32:27.572 PM xpcproxy[263]: assertion failed: 13A603: xpcproxy + 3438 [EE7817B0-1FA1-3603-B88A-BD5E595DA86F]: 0x2
10/26/2013 4:32:27.885 PM WindowServer[95]: Display 0x04272dc0: Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 12)
10/26/2013 4:32:28.059 PM authexec[269]: executing /System/Library/ScriptingAdditions/StandardAdditions.osax/Contents/MacOS/uid
10/26/2013 4:32:28.059 PM WiFiKeychainProxy[198]: [NO client logger] WIFICLOUDSYNC WiFiCloudSyncEngineCreate: created...
10/26/2013 4:32:28.060 PM WiFiKeychainProxy[198]: [NO client logger] WIFICLOUDSYNC WiFiCloudSyncEngineRegisterCallbacks: WiFiCloudSyncEngineCallbacks version - 0, bundle id - com.apple.wifi.WiFiKeychainProxy
10/26/2013 4:32:28.286 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelDevice.
10/26/2013 4:32:28.286 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelSharedUserClient.
10/26/2013 4:32:28.286 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDSIVideoContext.
10/26/2013 4:32:28.286 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelDevice.
10/26/2013 4:32:28.286 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelSharedUserClient.
10/26/2013 4:32:28.286 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMain.
10/26/2013 4:32:28.287 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMedia.
10/26/2013 4:32:28.287 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextVEBox.
10/26/2013 4:32:28.287 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOHIDParamUserClient.
10/26/2013 4:32:28.287 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOSurfaceRootUserClient.
10/26/2013 4:32:28.287 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class Gen6DVDContext.
10/26/2013 4:32:28.287 PM com.apple.audio.DriverHelper[274]: The plug-in named AirPlay.driver requires extending the sandbox for the mach service named com.apple.AirPlayXPCHelper.
10/26/2013 4:32:28.323 PM com.apple.audio.DriverHelper[274]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the IOKit user-client class IOBluetoothDeviceUserClient.
10/26/2013 4:32:28.323 PM com.apple.audio.DriverHelper[274]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.blued.
10/26/2013 4:32:28.323 PM com.apple.audio.DriverHelper[274]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.bluetoothaudiod.
10/26/2013 4:32:28.434 PM coreaudiod[182]: 2013-10-26 04:32:28.434022 PM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM,  44100 Hz, 16-bit, Stereo
10/26/2013 4:32:28.487 PM UserEventAgent[172]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
10/26/2013 4:32:28.819 PM com.apple.SecurityServer[15]: Session 100013 created
10/26/2013 4:32:29.037 PM PhotoStreamAgent[197]: ApplePushService: APSConnection being used without a delegate queue
10/26/2013 4:32:29.122 PM 1PasswordAgent[222]: reloadAllObjects
10/26/2013 4:32:29.435 PM imagent[207]: [Warning] Creating empty account: PlaceholderAccount for service: IMDService (iMessage)
10/26/2013 4:32:29.673 PM com.apple.NotesMigratorService[287]: Joined Aqua audit session
10/26/2013 4:32:29.756 PM SystemUIServer[180]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
10/26/2013 4:32:29.756 PM SystemUIServer[180]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
10/26/2013 4:32:29.781 PM secd[266]:  SecErrorGetOSStatus unknown error domain: com.apple.security.sos.error for error: The operation couldn’t be completed. (com.apple.security.sos.error error 2 - Public Key not available - failed to register before call)
10/26/2013 4:32:29.782 PM secd[266]:  securityd_xpc_dictionary_handler WiFiKeychainProx[198] DeviceInCircle The operation couldn’t be completed. (com.apple.security.sos.error error 2 - Public Key not available - failed to register before call)
10/26/2013 4:32:29.862 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 1
10/26/2013 4:32:29.866 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 2
10/26/2013 4:32:29.871 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 3
10/26/2013 4:32:29.876 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 4
10/26/2013 4:32:29.880 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 6
10/26/2013 4:32:29.885 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 7
10/26/2013 4:32:29.891 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 8
10/26/2013 4:32:29.895 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 9
10/26/2013 4:32:29.899 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 10
10/26/2013 4:32:29.905 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 11
10/26/2013 4:32:29.911 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 12
10/26/2013 4:32:29.915 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 13
10/26/2013 4:32:29.920 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 14
10/26/2013 4:32:29.924 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 15
10/26/2013 4:32:29.928 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 16
10/26/2013 4:32:29.932 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 17
10/26/2013 4:32:29.937 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 18
10/26/2013 4:32:29.942 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 19
10/26/2013 4:32:29.946 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 20
10/26/2013 4:32:29.951 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 21
10/26/2013 4:32:29.957 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 22
10/26/2013 4:32:29.963 PM com.apple.time[172]: Interval maximum value is 946100000 seconds (specified value: 9223372036854775807).
10/26/2013 4:32:29.964 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 23
10/26/2013 4:32:29.970 PM mDNSResponder[62]: ERROR: handle_resolve_request bad interfaceIndex 24
10/26/2013 4:32:30.019 PM iTunes[235]: TuneUp Plugin main received 'tini' from 10.9
10/26/2013 4:32:30.072 PM M4PConverter[291]: Load M4PConverter virtual CD Burner
10/26/2013 4:32:30.126 PM com.apple.kextd[12]: kext com.AhaMediaSoft.driver.M4PToMP3CDBurner  200009000 is in exception list, allowing to load
10/26/2013 4:32:30.139 PM com.apple.kextd[12]: Can't load /System/Library/StartupItems/CDBurnerService/CDBurner.kext - no code for running kernel's architecture.
10/26/2013 4:32:30.144 PM SystemStarter[48]: m4pTomp3 CD Burner (132) did not complete successfully
10/26/2013 4:32:30.145 PM SystemStarter[48]: The following StartupItems failed to start properly:
10/26/2013 4:32:30.145 PM SystemStarter[48]: /System/Library/StartupItems/CDBurnerService
10/26/2013 4:32:30.145 PM SystemStarter[48]:  - execution of Startup script failed
10/26/2013 4:32:30.302 PM com.apple.launchd.peruser.501[169]: (com.displaylink.useragent[293]) Job specified non-existent working directory: /System/Library/Extensions/DisplayLinkDriver.kext/DisplayLinkAgent
10/26/2013 4:32:30.302 PM com.apple.launchd.peruser.501[169]: (com.displaylink.useragent[293]) Job failed to exec(3). Setting up event to tell us when to try again: 2: No such file or directory
10/26/2013 4:32:30.302 PM com.apple.launchd.peruser.501[169]: (com.displaylink.useragent[293]) Job failed to exec(3) for weird reason: 2
10/26/2013 4:32:30.538 PM com.apple.time[172]:
@deurich you may want to see this discussion (it may be relevant):
https://github.com/iBaa/PlexConnect/pull/171
I created a new app with some fixes that matches Mavericks and can't replace the icon .. I downloaded the picture a few posts up and changes extension to .icns .. And it just showing new the preview photo with .icns on it .. From the get info it doesn't changes too
Icon guide moved to here:
To change the icon of any app first select get info on the app you want to change to a new icon. Open the icon file as a .png in safari. Drag and drop from safari the desired picture(.png) onto the icon in get info you opened previously. Drag it to the same place it says test.html as the example below illustrates. You actually could drag and drop the icon from the post above if you opened this forum in safari to your app. This is extremely easy to do. Do not change the extension to .icns.
If for some reason you cant get it to work, download and open my plexconnect app posted above in automator and change the applescript code to whatever you want, save it in automator and you should be able to figure out the rest.
Awesome. Thanks
Thank you! That thread worked by adding in the delay as suggested in the thread. Cheers.
