Hash sum mismatch error
Hi everyone,
This morning I see on my PMS an update. But when I want to upgrade this error appears :
So I have re-add the apt-key with follow this article :
and with this command : sudo curl https://downloads.plex.tv/plex-keys/PlexSign.key | sudo apt-key add -
But that problem is still here so I have remove all file in the folder /var/lib/apt/lists/ with this command : sudo rm -rf /var/lib/apt/lists/*
My serveur run in Debian 9.3 and is up to date !
Thank you very much for your answer,
P.S: I’m french guy so please if there are some fault please excuse me ! (If you want you can correct me ! :smiley: )
Glingling
Hello,
I have exactly the same issue when I’m doing “apt-get update”.
My server run on Debian Jessie 9.3 too.
Which version are you download please? I am looking at 1.11.3.4803 and finding different results.
I am working with the team now to find out why this is happening.
[chuck@lizum ~/Downloads.106]$ echo c3d4b6fc44340304b8fa95b682e17c4bac96a00f ; sha1sum plexmediaserver_1.11.3.4803-c40bba82e_amd64.deb
c3d4b6fc44340304b8fa95b682e17c4bac96a00f  plexmediaserver_1.11.3.4803-c40bba82e_amd64.deb
Hello,
Right now, I have the version 1.10.1.4602.
And, Plex told me there is a new version (1.11.3.4803). So, I guess the v. 1.11.3.4803 is the one I tried to download with apt-get.
Please check again. PMS 1.11.3 should also be available to you in Public.
If you are not seeing it, please capture the screen shot and let me know?
@Zancrow
@grogster
@Glingling
We found a problem and fixed it.
Please verify
Issue just fixed for me (I was going to share my logs)
Thanks!
@ChuckPA Works for me, thank you :slight_smile:
Glad it’s ok for you.
There seems to be a regional problem. Some report failure. I too am seeing 1.10.1 / hash failure.
I was gonna say, all people reporting the problem are french.
Works for me too !
Thank you !
I’m having the same issue trying to download version 1.16.0.1226 as well from the repository. Is this something on plex’s end or do I need a different key than the one on article link?
I have reported this.
Please do go to any other thread as they are more current and with the new repositories.
This should have been closed when we moved to 1.15.0.
Sorry for that.
