Recently I removed the dev2day repository as per instructions, and then added the new repository as outlined on this page
Now whenever I run an apt-get update I get this message:
W: Failed to fetch https://downloads.plex.tv/repo/deb/dists/public/main/binary-armhf/Packages Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
Any help would be greatly appreciated!
Can you download the file and show the hash?
Also, which version?
Is happening exactly the same thing to my plex installation on my raspberry pi server. The version I’m using is 1.16.2.1297
it was working fine till last update, but from today onwards happening to me as well,
Plex Server 1.16.2.1297 on jessie, raspberry pi
until this version, update happen without an issue
did the following but same issue
sudo apt-get clean
and
sudo rm -rf /var/lib/apt/lists/*
and
sudo rm -rf /var/lib/apt/lists/partial
no luck, same issue
p.s. my system was originally upgraded from dev2day some time back, working fine since then.
There was another user today who found his key was corrupted.
I suggest the same procedure as next step. Reestablish the signing keys
Also having this error
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://downloads.plex.tv/repo/deb public Release: The following signatures were invalid: BADSIG 97203C7B3ADCA79D Plex Inc.
W: Failed to fetch https://downloads.plex.tv/repo/deb/dists/public/Release.gpg The following signatures were invalid: BADSIG 97203C7B3ADCA79D Plex Inc.
W: Some index files failed to download. They hav…
Unfortunately it looks like my key wasn’t corrupted and these steps didn’t work. There was no “unknown” next to mine.
I’m still running version 1.15.4.993. I’m also still running Raspbian Jessie. Might this be an issue?
Anything is possible. If you have the installation DEB, you’re free to change installed versions at will.
So you’re recommending updating the distro? Because it seems like others are having this problem.
It’s a Pi issue. I don’t know the Pi processor other than it’s ARMv8.
@drmagoo would know far more than I do (resident Pi Meister)
installed using the guide
https://support.plex.tv/articles/235974187-enable-repository-updating-for-supported-linux-server-distributions/
still apt-get update fail with the same error.
keys are
pub 4096R/3ADCA79D 2015-03-22
uid Plex Inc.
sub 4096R/132DFBE0 2015-03-22
MoodZy
July 20, 2019, 6:09am
11
I do have the same problem using my Pi. As of now none of the proposed solutions solved the problem.
Same problem here with a pi3
for me it started to work without me doing anything.
Everything is working for me now but I didn’t do anything
system
Closed
October 21, 2019, 7:54am
15
