Drivers are available in the kernel and the firmware is up to date. The kernel seems to detect and initialise it correctly and I get a message in the plex log about detecting it but not supported (this is a tuner for Australian TV networks)
Any hope of this tuner being supported in the future or do I just drop in the drawer full of unsupported USB tuners and wireless devices and buy yet another one… ![]()
thanks
Plex logs
Sep 10, 2017 11:20:31.952 [0x7f6ec4ffe700] DEBUG - DVR:Device: Discovering and refreshing devices.
Sep 10, 2017 11:20:31.953 [0x7f6ec4ffe700] DEBUG - DVR:Grabber: HDHomerun discovered 0 compatible devices.
Sep 10, 2017 11:20:31.953 [0x7f6ec4ffe700] DEBUG - DVR:Grabber: Mystery discovered 0 compatible devices.
Sep 10, 2017 11:20:31.953 [0x7f6ec4ffe700] DEBUG - HTTP requesting POST http://127.0.0.1:32600/devices/discover
Sep 10, 2017 11:20:34.367 [0x7f6ec4ffe700] DEBUG - HTTP 200 response from POST http://127.0.0.1:32600/devices/discover
Sep 10, 2017 11:20:34.367 [0x7f6ec4ffe700] DEBUG - DVR:Grabber: Ignoring (NovaT 500Stick) which is an unsupported tuner device.
Sep 10, 2017 11:20:34.368 [0x7f6ed0bff700] DEBUG - Completed: [127.0.0.1:35978] 200 POST /media/grabbers/devices/discover (5 live) GZIP 2415ms 470 bytes (pipelined: 11)
Kernel logs (dmesg)
[ 87.810455] usb 2-1.6: new high-speed USB device number 3 using ehci-pci
[ 87.903432] usb 2-1.6: New USB device found, idVendor=2040, idProduct=5200
[ 87.903436] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 87.903437] usb 2-1.6: Product: NovaT 500Stick
[ 87.903439] usb 2-1.6: Manufacturer: Hauppauge
[ 87.903440] usb 2-1.6: SerialNumber: 4034038833
[ 87.959347] media: Linux media interface: v0.10
[ 88.086699] dvb-usb: found a ‘Hauppauge Nova-TD Stick (52009)’ in cold state, will try to load a firmware
[ 88.109479] dvb-usb: downloading firmware from file ‘dvb-usb-dib0700-1.20.fw’
[ 88.310839] dib0700: firmware started successfully.
[ 88.814881] dvb-usb: found a ‘Hauppauge Nova-TD Stick (52009)’ in warm state.
[ 88.815049] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 88.815230] dvbdev: DVB: registering new adapter (Hauppauge Nova-TD Stick (52009))
[ 88.815235] usb 2-1.6: media controller created
[ 88.815416] dvbdev: dvb_create_media_entity: media entity ‘dvb-demux’ registered.
[ 89.231177] usb 2-1.6: DVB: registering adapter 0 frontend 0 (DiBcom 7000PC)…
[ 89.231187] dvbdev: dvb_create_media_entity: media entity ‘DiBcom 7000PC’ registered.
[ 89.449984] dib0070: DiB0070: successfully identified
[ 89.450229] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 89.450732] dvbdev: DVB: registering new adapter (Hauppauge Nova-TD Stick (52009))
[ 89.450737] usb 2-1.6: media controller created
[ 89.450942] dvbdev: dvb_create_media_entity: media entity ‘dvb-demux’ registered.
[ 89.607289] usb 2-1.6: DVB: registering adapter 1 frontend 0 (DiBcom 7000PC)…
[ 89.607302] dvbdev: dvb_create_media_entity: media entity ‘DiBcom 7000PC’ registered.
[ 89.826469] dib0070: DiB0070: successfully identified
[ 89.886909] Registered IR keymap rc-dib0700-rc5
[ 89.887143] rc rc0: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/rc/rc0
[ 89.887204] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/rc/rc0/input13
[ 89.887366] dvb-usb: schedule remote query interval to 50 msecs.
[ 89.887371] dvb-usb: Hauppauge Nova-TD Stick (52009) successfully initialized and connected.
[ 89.887633] usbcore: registered new interface driver dvb_usb_dib0700
