'HD Channels Only' is showing some SD channels again
I have noticed the ‘HD Channels Only’ filter is showing some SD channels again here in the UK. It did this a while ago and was fixed in an update. Seems that bug has come back again in the latest releases :sob:.
I’d be very surprised if this was ever “fixed in an update“. Last I heard from Plex it selects HD by content and not by channel regardless of what the drop-down says.
Yeah… I have just been looking at other posts and apparently it is done by content regardless of whether it is on an SD channel or not. Basically a pointless drop-down. If the channel is being broadcast in SD it is never going to be an HD recording.
What would be nicer is if you could create your own custom filters. Then I could create a list I know are HD channels and also filter out the rubbish (Effectively a favourites drop-down).
