I know this has been discussed, but I’m trying to figure out what’s all happening and what’s a good solution. My server runs on a Mac. I have the HDHomeRun Extend. We never watch Live TV. My main player is Apple TV (4th gen) Previously, Plex was set to “high quality” and HDHR to “Heavy” and a 1hr program with commercials is about 1.75GB. I recently changed it to Plex (original) and HDHR (heavy), and will do some recordings tonight.
What’s making me investigate this is the Plex app on the Apple TV has issues on a Direct Stream of 1 show or channel. But if I transcode using Handbrake (Apple Surround 30), I get a much smaller file and it direct plays perfectly. Or the direct play of .TS in Infuse works well too. I believe Handbrake will spit out about the same file size regardless of the Plex/HDHR settings.
Is the .TS container Plex records to an MPEG2 with H264?
I’m thinking a post process script using HandbrakeCLI would do the trick to give me a more comparable and smaller file. But unfortunately, I only have novice command line skills and zero scripting skills. And what transcoding settings I should feed into that (like, is it bad if HDHR transcodes, then Handbrake does it’s thing). Or if it even matters.
Any help is appreciated. My apologies if I got some terminology wrong.
The Extend has only two tuners, as compared with Quattro’s four. But if PLEX can’t take advantage of the hardware transcode then it’s not worth it.
