This fixed my issue with Unraid using Docker container and an Intel 9900K. Thanks!
Do I need to do something if I’m using PMS on my Unraid server, using a i3 10100?
/Söder
Hi, came here hoping to find plex had a solution, but this is it.
Thanks for providing a working dockerfile. Saved me so much time.
Trying to run this on ubuntu 21.04 and I’m getting errors when I get to the make command.
Also llvm-7 clang-7 and libclang-7 are not available when installing from apt, so I tried with version 9 and 12 and still error out
any suggestions?
Don’t change the Dockerfile to 21.04, you don’t need to match your base OS version. Is that what you’re doing?
I just ran docker build on this Dockerfile, still works for me.
I should clarify, I’m not using docker. I used the commands from the docker file, which are roughly the same as those suggested on the GitHub page by the author of the updated repo
