Headless Player : Bit perfect
Hi everyone,
Like many people, i use plexamp with headless Raspberry PI configuration (with Allo Digione DAC).
First, there is the log :
Nov  7 20:24:47 raspberrypi node[1964]: Audio: Set player info.
Nov  7 20:24:47 raspberrypi kernel: [ 1475.809759] bcm2835-i2s 3f203000.i2s: I2S SYNC error!
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] BASS: Starting up.
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] Device 1: Default - enabled default - sample rates:
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] Device 2: snd_allo_digione:  - enabled - sample rates:
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] Device 3: JACK Audio Connection Kit - enabled - sample rates:
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] Device 4: PulseAudio Sound Server - enabled - sample rates:
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] BASS: Using plugin path '/home/pi/plexamp/server/node_modules/treble/build/Release/'.
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] BASS: Reloading ourselves for symbol visibility.
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] BASS: Version 2.4.13.8
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] BASS: Mixer version 2.4.9.2
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] BASS: Going to try to open device with sample rate of 44100.
Nov  7 20:24:47 raspberrypi node[1964]: #033[33mdebug#033[39m: [TREBLE] BASS: Device opened and sample rate is 44100, latency is 34ms (minimum buffer: 14ms).
As you can see, sample rate is forced 44,1k (and 16bit i suppose).
But many of my flac files are 24/48 or 24/96, is it possible to keep the initial sample rate and entrust the treatment to the dac in perfect bit mode ?
Better support for this sort of thing is on our future list for sure!
Thanks for answers @elan !
This future is in some week? month ? years? :stuck_out_tongue:
And last question news of the future version of Plexamp Headless release ?
Thanks again :wink:
bump @elan :slight_smile:
An another easy way is to implement “Push to DLNA renderer” ou implement Search in Dlna Plex server :stuck_out_tongue:
@elan
Bump …
Super curious where this project stands. Are we looking at a new beta or 1.0 release any time soon, perhaps with a ready-baked image?
Hi :slight_smile:
Congrats for plexamp V3 release )
This version is bitperfect ?
Not yet in all cases :slight_smile:
Is that something we might see in the near future on any platforms? I use pa on Mac and RPI and I love it as a casting destination - the combo is better than any of the others I’ve used, but bitperfect to my dac would be so nice.
Is this a project anyone can contribute to? I’d love to help.
Dunno about “near” (don’t like to set expectations improperly), but it’s basically the next bigger push for the player layer.
It would be awesome to have some kind of confirmation of bit-perfect/direct play in the app (like roon’s signal path view).
